ISY and Smoke Bridge
I have been using an insteon smoke bridge with my first alert smoke detectors.  I got it to work when I pressed test, and it shows TEST as ON in the isy software.  The only way to get that to turn off is to manually click query.  Am I doing something wrong??  Shouldn't it auto query?
It’s a limited interface. To fill in a little more, the communication is effectively one way from the linked first alert to the bridge. Also good to know is that the battery alert works only for the unit linked to, not the others... and it’s not possible to know which smoke/co detector triggered, just that one did.
