Get ISY Status using a windows software
I'm trying to add the ability to get my ISY status from the portal to one of my windows forms software. I know there is an API for REST interface
https://wiki.universal-devices.com/index.php?title=ISY_Developers:API:REST_Interface
and another API called soup
https://wiki.universal-devices.com/index.php?title=ISY_Developers:API:Soap
that has this command
GetCurrentSystemStatus (string SID)
The problem it shows no syntax on actually how to call the REST command or how to point it to the ISY portal. the examples only show the response to the REST calls. I would probably also need a way to set the API in the code and an API key. Any idea how to get that? Any suggestions will be of great help.
Michel,
I don't need devices status. Only the ISY status, I need to know if it is online or offline (connected to the portal or not).
