  • 1 year later...
I run with the 500 series board and all my z wave devices are 500 series. Is this board compatible with the new 700 series Z Wave devices ? And is there a plan to provide an upgraded 700 series ISY controller board ?
This is a closed thread. You should create a new post for your question
The 700 series devices should be backward compatible with the 500 series, however some security features may not be available.  As far as I know there are no plans for a 700 series board for the ISY.  In the future the Polisy, which will probably replace the ISY,  will most likely support an external 700 series dongle..
