Amazon echo saying "not responding" and "no device found"
2 hours ago, rccoleman said:
This was pretty bad last night and this morning, to the point that I ended up using the keypad in my bedroom instead.  Last night, I kept getting "Downstairs lights are not responding" over and over again with it not actually turning off the lights, and then it finally worked after 10-15 mins or so. In the morning, it acted like it recognized "Good Morning", but did nothing over several attempts.  I eventually just hit the keypad button that runs the exact same program and it worked immediately.
Has anyone else had issues with Alexa in the last 12-24 hours?  None of my devices are showing "offline" at alexa.amazon.com, and weren't last night.
This could be a router problem. I had some problems like that when my router was acting up. Data makes it through most of the time but sometimes you get delays and things give up trying.
I have had to power cycle my router a few times where soft reboots haven't worked. May be worth a try.
The issue with ‘good morning’ turned out to be self inflicted when I ‘forgot’ all of my devices and rediscovered them the night before in an attempt to fix the ‘not responding’ issue. That erased the actions in all of my routines and I had to add them back. That’s working now.
I really don’t think this is a connectivity problem. I’m using a fully updated, high quality pfSense router and there was no evidence of connectivity issues at the time. In any case, it hasn’t recurred and I’ll do more investigation if it happens again.
@rccoleman,
Two questions:
1. What does Echo history show? Did she hear/interpret the command properly?
2. Do you have any errors in the error log?
5 hours ago, Michel Kohanim said:
@rccoleman,
Two questions:
Yes, the Alexa app indicates that the Echo heard the right thing every time.  The error log does appear to be interesting.  I started getting these errors right around the time of the failed Alexa commands, and they're actually continuing through today, despite the fact that my Alexa commands and everything else is working fine.
Mon 2018/09/03 08:15:57 AM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 33
Mon 2018/09/03 08:16:15 AM	System	-170001	[UDSockets] HTTP:29 error:6
Mon 2018/09/03 11:50:45 AM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 32
Mon 2018/09/03 11:52:21 AM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 33
Mon 2018/09/03 03:34:54 PM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 32
Mon 2018/09/03 04:15:00 PM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 33
Mon 2018/09/03 09:29:50 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 06:52:32 PM	System	-5012	96
Mon 2018/09/03 09:24:52 PM	System	-170001	[UDSockets] RSub:22 error:6
Mon 2018/09/03 09:24:57 PM	System	-5012	87
Mon 2018/09/03 09:30:01 PM	System	-170001	[TCP-Conn] -6/-140002, Net Module Rule: 32
Mon 2018/09/03 09:35:01 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:35:37 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:41:09 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:52:12 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:52:54 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:53:04 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:53:14 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:53:25 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:53:35 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:53:56 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:54:06 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:54:16 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:55:09 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:55:19 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:55:29 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:57:30 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 09:57:40 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:03:54 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:04:04 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:04:14 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:03:04 PM	System	-5011	uuid:0
Mon 2018/09/03 10:04:27 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:32 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:38 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:43 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:49 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:54 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:04:56 PM	System	-5006	uuid:0
Mon 2018/09/03 10:05:00 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:05 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:11 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:16 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:22 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:27 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:33 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:38 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:44 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:49 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:05:55 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:00 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:06 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:11 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:17 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:22 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:36 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:06:29 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:34 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:39 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:44 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:46 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:06:56 PM	System	-170001	UDQ: Queue(s) Full, message ignored
Mon 2018/09/03 10:06:49 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:06:55 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:00 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:06 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:07 PM	System	-5006	uuid:0
Mon 2018/09/03 10:07:15 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:21 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:26 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:32 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:37 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:43 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:48 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:07:54 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:00 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:05 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:11 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:16 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:17 PM	System	-5006	uuid:0
Mon 2018/09/03 10:08:22 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:27 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:33 PM	System	-170001	[UDSockets] PSub:42 error:6
Mon 2018/09/03 10:08:38 PM	System	-170001	[UDSockets] PSub:42 error:6
I'm still getting these "error:6" messages every 5-10s this morning.  Is that the connection to the portal?  At the time, and even now, the portal lists my ISY as online.  Here's the tail end of the error log:
Wed 2018/09/05 09:02:07 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:12 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:17 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:22 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:27 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:32 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:37 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:42 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:47 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:52 AM	System	-170001	[UDSockets] PSub:42 error:6
Wed 2018/09/05 09:02:59 AM	System	-170001	[UDSockets] PSub:42 error:6
Is there any more useful data to be collected on the ISY for this?  I'm tempted to reboot to get it out of whatever state it's in, even though it seems to be working.
Edited by rccoleman
I have a few of these every day. It is getting to the point that Alexa is simply not dependable. Even though I often get feedback that a spoken was executed, in point of fact, it wasn't.
@rccoleman, everything is related to:
It seems that ISY is just way too busy. The error 6 is for PSub (Portal subscription) and not the actual portal connection. I wouldn't worry about it
The main question is: what has happened to your system such that you have all these queue full errors?
@smokegrub, have you also looked at your error log?
Candidly, Michel, I would not know what I was looking at even if I knew where to find that log. I cannot imagine what might be happening that would make my ISY so busy. As you know, I have two portals which deal with separate Google accounts on separate ISYs. Of course, any help will be appreciated because use of Alexa has become so undependable as to be almost useless.What are the types of things that can affect the ISY's queue?
Edited by smokegrub
@smokegrub,
Can you tell me what is installed on your ISY? i.e. node servers, Z-Wave, etc.? You can also send me your Tools | Error Log.
14 minutes ago, Michel Kohanim said:
@smokegrub,
No nodeservers, no Zwave just Smarthome devices and Alexa. I tried to upload the error log but it is 2.6 mb and didn't load. Shall I copy a portion of it and attach?
I don't really know how to answer that, other than to provide the log.  The only thing that I see is that the Z-Uno temp sensor, which is asynchronously reporting it's temperature every 5 seconds until it reaches the target temp, all seem to be bunched together.  That's a little weird because I can usually watch it report at 5 second intervals, so I don't know what might have caused them to all be reported at once (other than the other discussion that we're having in the other thread, perhaps).  To be clear, I set a parameter that tells the temp sensor to start reporting at 5 second intervals when I want hot water, and I tell it to stop when it reaches the right temp (between 1 and 3 mins).
Quote
Arm Night    ELK-ERR     House    Mon 2018/09/03 09:27:40 PM    System
Devices / Harmony / Bedroom    Custom Control 3    -1    Mon 2018/09/03 09:27:41 PM    System
Devices / Harmony / Bedroom / Watch TV    Status    TRUE    Mon 2018/09/03 09:27:41 PM    System
Devices / Harmony / Bedroom    Custom Control 3    3    Mon 2018/09/03 09:27:41 PM    System
Devices / Master Bathroom / Recirc Pump OnOff    Status    On    Mon 2018/09/03 09:27:42 PM    System
Devices / Foyer / Entryway Lamp    Status    100%    Mon 2018/09/03 09:27:43 PM    System
Devices / Master Bedroom / Outside Floor Lamp    Status    100%    Mon 2018/09/03 09:27:43 PM    System
Devices / Master Bedroom / Door Torchiere Light    Status    100%    Mon 2018/09/03 09:27:43 PM    System
Devices / Master Bedroom / Corner Torchiere Light    Status    100%    Mon 2018/09/03 09:27:43 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    73.05¬∞F    Mon 2018/09/03 09:27:43 PM    System
Devices / Upstairs Ecobee / Upstairs Ecobee    Custom Control 2    -1    Mon 2018/09/03 09:27:45 PM    System
Devices / Master Bedroom / Keypad / MB Keypad - Upstairs Lights    Status    On    Mon 2018/09/03 09:27:47 PM    System
Devices / Kitchen / Kitchen Lights Keypad / K Keypad - Upstairs Lights    Status    On    Mon 2018/09/03 09:27:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    73.16¬∞F    Mon 2018/09/03 09:27:55 PM    System
Devices / Downstairs Hallway and Bar / Recessed Light (Bar)    Status    Off    Mon 2018/09/03 09:29:44 PM    System
Devices / Downstairs Hallway and Bar / Recessed Light (Foyer)    Status    Off    Mon 2018/09/03 09:29:44 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2674    Mon 2018/09/03 09:29:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    73.50¬∞F    Mon 2018/09/03 09:29:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    73.85¬∞F    Mon 2018/09/03 09:29:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    74.17¬∞F    Mon 2018/09/03 09:29:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    74.51¬∞F    Mon 2018/09/03 09:29:49 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    74.85¬∞F    Mon 2018/09/03 09:29:49 PM    System
Devices / Wireless Tags / Master Bedroom    Custom Control 13    1536035344    Mon 2018/09/03 09:29:50 PM    System
Devices / Wireless Tags / Chest Freezer    Current Temperature    -1.1¬∞F    Mon 2018/09/03 09:29:50 PM    System
Devices / Wireless Tags / Chest Freezer    Humidity    56.10%    Mon 2018/09/03 09:29:50 PM    System
Devices / Wireless Tags / Chest Freezer    Custom Control 13    1536035380    Mon 2018/09/03 09:29:50 PM    System
Devices / Wireless Tags / Chest Freezer    Custom Control 14    0    Mon 2018/09/03 09:29:51 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    95.00¬∞F    Mon 2018/09/03 09:29:56 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    96.56¬∞F    Mon 2018/09/03 09:29:56 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    97.80¬∞F    Mon 2018/09/03 09:29:57 PM    System
Devices / Master Bathroom / Z-Uno Temp Sensor    Current Temperature    99.05¬∞F    Mon 2018/09/03 09:29:58 PM    System
Devices / Master Bathroom / Recirc Pump OnOff    Status    Off    Mon 2018/09/03 09:29:59 PM    System
Arm Away    ELK-ERR     House    Mon 2018/09/03 09:30:03 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2675    Mon 2018/09/03 09:30:03 PM    System
Devices / Master Bedroom / Master Closet Light, Left    Status    100%    Mon 2018/09/03 09:30:24 PM    System
Devices / Master Bathroom / Vanity Light    Status    100%    Mon 2018/09/03 09:30:36 PM    System
Devices / Master Bathroom / Shower Light    Status    100%    Mon 2018/09/03 09:30:36 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2676    Mon 2018/09/03 09:30:39 PM    System
Devices / Downstairs Office / Motion Sensor-Dusk.Dawn    Status    Off    Mon 2018/09/03 09:31:48 PM    System
Devices / Downstairs Office / Lights    Status    Off    Mon 2018/09/03 09:32:21 PM    System
Devices / Downstairs Hallway and Bar / Coat Closet Sensor    Luminance    3 lux    Mon 2018/09/03 09:32:28 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2674    Mon 2018/09/03 09:32:28 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2673    Mon 2018/09/03 09:32:28 PM    System
Devices / Master Bedroom / Master Closet Motion, Left-Du    Status    Off    Mon 2018/09/03 09:34:54 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2674    Mon 2018/09/03 09:35:00 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2673    Mon 2018/09/03 09:35:03 PM    System
Devices / Wireless Tags / Freezer    Custom Control 14    2712    Mon 2018/09/03 09:35:03 PM    System
Devices / Wireless Tags / Dining Room Wine Fridge    Humidity    65.30%    Mon 2018/09/03 09:35:03 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2672    Mon 2018/09/03 09:35:03 PM    System
Devices / Wireless Tags / Dining Room Wine Fridge    Custom Control 13    1536035663    Mon 2018/09/03 09:35:03 PM    System
Devices / Wireless Tags / Dining Room Wine Fridge    Custom Control 14    0    Mon 2018/09/03 09:35:03 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2674    Mon 2018/09/03 09:35:04 PM    System
Devices / Wireless Tags / Master Bedroom    Custom Control 14    54    Mon 2018/09/03 09:35:04 PM    System
Devices / Wireless Tags / Side¬†Yard    Custom Control 14    311    Mon 2018/09/03 09:35:04 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2675    Mon 2018/09/03 09:35:04 PM    System
Devices / Wireless Tags / Dining Room Wine Fridge    Custom Control 14    633    Mon 2018/09/03 09:35:04 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2673    Mon 2018/09/03 09:35:06 PM    System
Devices / Master Bedroom / Master Closet Light, Left    Status    Off    Mon 2018/09/03 09:35:24 PM    System
Devices / Downstairs Office / Motion Sensor-Dusk.Dawn    Status    On    Mon 2018/09/03 09:35:25 PM    System
Devices / Wireless Tags / Master Bedroom    Custom Control 13    1536035723    Mon 2018/09/03 09:35:30 PM    System
Devices / Wireless Tags / Master Bedroom    Current Temperature    72.6¬∞F    Mon 2018/09/03 09:35:30 PM    System
Devices / Wireless Tags / Master Bedroom    Custom Control 14    0    Mon 2018/09/03 09:35:30 PM    System
Devices / Wireless Tags / Master Bedroom    Humidity    63.30%    Mon 2018/09/03 09:35:30 PM    System
Devices / Downstairs Ecobee / Office    Custom Control 1    1    Mon 2018/09/03 09:35:30 PM    System
Devices / Upstairs Hallway / Whole House Fan    Status    Off    Mon 2018/09/03 09:35:31 PM    System
Devices / Downstairs Ecobee / Downstairs Hallway    Status    79¬∞    Mon 2018/09/03 09:35:37 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2672    Mon 2018/09/03 09:35:38 PM    System
Devices / Master Bedroom / Master Closet Motion, Left-Du    Status    On    Mon 2018/09/03 09:38:29 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2674    Mon 2018/09/03 09:38:36 PM    System
Devices / Garage / Garage Door multi-level    General Purpose Value    2673    Mon 2018/09/03 09:38:36 PM    System
I bolded the line around the first "queue full" line in the error log.  I'm just surprised that it didn't recover eventually and keeps spewing errors in the error log.
Still sounds like a new router problem. The fancier they get, the more problems come forward.
I have three newer style routers and the reason for the latest two purchase were similar problems. The newest one does things like this too. All different brands and they all need cold boots occasionally despite the 15 upgrades and Merlin new and improved, less hangs. firmware. One of the biggest factors I found, almost every summer, is they overheat with the dual core 1Ghz ++ cores. Vertically mounting the last two helped immensely.
