Homeseer Fan Control HS-FC200+
Most of the homeseer stuff works with the ISY if you are using the beta firmware.
It might not have all the features supported yet, but they are adding stuff all the time.
Reading the amazon reviews for it it seems less than intuitive, but if you are up for it give it a go!
  • 4 weeks later...
I can confirm that it works well in the ISY. Including the multi-tap (2 tap and 3 tap)
  • 7 months later...
Hi @silverton38 - I just purchased one of these, but haven't installed it yet.  The instructions state that you can control on/off remotely, but doesn't say anything about controlling the speed remotely.  Does the switch look like and on/off switch to the ISY, or a dimmer?  Can you control the speed remotely?
Yes, supports 3 or 4 speed fans. Mine are 3 speed so 1-33% = low, 34-66% = med, >66% = high. Works great.
