Disable Mini Remote Dimming?
Hi-
I'm trying to use a mini remote to toggle some hard-to-reach plug-in appliance modules.
I put them into a scene together on the isy, and seems to work fine, except that occasionally, if I press a little long on the mini remote, it will try to put the module into a dimming state instead of an on / off state.  But the module only does on/off.
Is there some way to set the mini remote just to toggle on/off, and not do any dimming (either through the isy, or on the mini remote directly?)
Holding any insteon button down will always send the dim command. There is no way to override that. If something isn't dimmable, it simply won't dim
4 hours ago, Nugen said:
Hi-
Welcome to the forum!
Sure. ISY can do almost anything.
     Control MiniRemote is switched 'fade up'
     set Whatever to On.
Even SwitchLinc wall switches (with no dimming) will put out six different codes. On / Off / Fast On / Fast Off / Fade Up / Fade down. I use one MiniRemote to control 24 test programs.
Thank you!
This is very helpful. This is actually more or less what I had tried- I wasn't given the option for 'Control MiniRemote is switched 'fade up' ', but I just set it >1.
It seems my issue was that I was setting the Then response to the device in the scene, rather than directly to the device itself.  When I switched that, it worked.
Of course, because I don't have 'fade-up' as an option, I also don't have what I presume to be the analogous 'fade down', so this only works in one direction.
This is fine for my purposes, but it does make me wonder why I don't have 'fade-up' and 'fade-down' as conditions.  Any ideas on that?
Thanks again!
  • 1 month later...
