Status vs Activity
I do not think I understand the difference in the Program summary tab between these two condition. I have some programs that have completed so they are "Idle" under the Activity column, but still "True" under the Status column. I am confused because I want to write other programs that are contingent on the condition of another program running, but even though it is "Idle" the other program (because it says "True") apparently still thinks its running
Please help
Thx
Joe
Please help
Thx
Joe
By default Programs are all False until they have been evaluated at least once, then they may become True. They will remain True until the conditions change. It doesn't matter if they are currently Running. Programs can be False and Running depending on the Actions in the Else section.
Rand
OK, so how do your write a program that executes (or does not execute) based on whether another program is running? I was using the "Status" but that seems useless
Thx
Joe
Joe,
By using the "run else path" at the end of your program you can force the program to false when it completes. As a result, the status will only be true when it is actually executing.
Program Test
IF A,
or B
or C
set A
Set B
Set C
Run Program Test (Else Path)
--No actions
end
so thereis a selection calls "run else path"?. I will check when I get home.
Joe
This should not be this tough. I am trying to have two KPL button, B & D, that are listed as mutually exclusive turn on the pool pump for 1 hr or 2 hr respectively, but when I run the programs below by hitting Button B first then Button D, program B is still running
Control 'KPL Pool Eq B' is switched On
And Control 'KPL Pool Eq B' is not switched Off
Or Control 'KPL Pool Eq D' is not switched On
Wait 2 seconds
Send X10 'K16/On (3)'
Wait 1 hour
Send X10 'K16/Off (11)'
Run Program 'Pool on 1 HR KPL' (Else Path)
Control 'KPL Pool Eq D' is switched On
And Control 'KPL Pool Eq D' is not switched Off
Or Control 'KPL Pool Eq B' is not switched On
Wait 2 seconds
Wait 2 hours
Run Program 'Pool on 2 HR KPL' (Else Path)
