December 9, 20187 yr 39 minutes ago, CopyRon said: Live update is missing from my portal in echo connectivity. It was removed in the last Portal update.
December 9, 20187 yr Author "Amazon Echo: The live update button has been removed. It will be enabled automatically if the skill is enabled." Thanks
December 9, 20187 yr You're right. It's missing for me as well. I tried unlinking and linking again but no change. I'm also receiving and error in the portal "Devices are not available HTTP error 500"
December 9, 20187 yr @DaveStLou, Not sure I understand. Live Update was removed in the last maintenance release. It's enabled automatically. If you have other problems, please submit a ticket or provide more details. With kind regards, Michel
December 9, 20187 yr Author I think we were thinking the button gets re-enabled automatically, and you're say that the live up date feature is automatic and no longer requires us to select it.
December 10, 20187 yr +1 here, assumed functionality was removed, didn’t bother since never worked as it should have
December 12, 20186 yr On 12/9/2018 at 2:25 PM, Michel Kohanim said: @DaveStLou, Not sure I understand. Live Update was removed in the last maintenance release. It's enabled automatically. If you have other problems, please submit a ticket or provide more details. With kind regards, Michel I was confused by the wording. It's working as designed.
