Next Stop 5.0?
4 hours ago, Michel Kohanim said:
Usually there are two cases:
1. You are not using the correct UI. You need to make sure you are using the ISY Launcher
2. If there are errors, you will see the issue in the comment section
You can save one at a time. There are no CLIs.
@Michel Kohanim
I'm using the UI that the ISY Launcher launched. The firmware loaded is the one I downloaded for use without a PLM so it has OADR in its name - do I need to find a way to load a OADR version of UI too? If so, how do I do that?
A quick scan of several 'not saved' programs have no comments that I didn't put in so I guess this confirms there are no problems with those?
Did you mean to say you "can't" save one at a time? If not, can you please tell me how to save one at a time?
1 hour ago, Michel Kohanim said:
@johnnyt,
You firmware and UI are correct. Please upgrade to 5.0.15A and, if you still problems (you need to save), please send your backup to support@universal-devices.com.
Upgraded to 5.0.15A and there are now over 480 programs that are "not saved" - about 20 more? Sent backup created using 15A to support email address.
  • 3 weeks later...
to close on this, the problem was that I didn't hit "save" because I thought I would lose the list of programs I have to fix but you have to hit save for the conversion to complete. Then you see what's left to fix.
Mention it because I don't remember seeing that in the instructions (and still didn't see it in the quick scan I just did) but there are lots of them so easy to miss.
