Help with a Simple Programs
Not sure if this is the correct place to post this, feel free to move it.
I'm new to ISY, and have been able to accomplish a few programs through trial and error.
I'm having difficulty getting my porch light which is controlled from an X-10 switch to turn on 30 minutes before sunset, and 30 minutes after sunrise. I have attached the program below, I have tried this numerous ways, and always get the same result, nothing. Any guidance on this matter would be greatly appreciated.
Sincerely,
Mike
Front Porch Light - [ID 0008][Parent 0001][Run At Startup]
        From    Sunset  - 30 minutes
        To      Sunrise + 30 minutes (same day)
        Send X10 'A14/On (3)'
        Set 'Front Porch Light' On
        Send X10 'A14/Off (11)'
        Set 'Front Porch Light' Off
I'm not exactly sure what you're asking, but this program turns on my external lights 30 minutes prior to sunset, and shuts them off 5 minutes prior to sunrise the next day.
ExternalLightingOn - [ID 0002][Parent 000A]
        To      Sunrise -  5 minutes (next day)
        Set 'Scenes / scnExternalLights' On
        Set 'Scenes / scnExternalLights' Off
Turns house external lighting on 30 minutes prior to sunset every day.  Lights go off at sunrise.
Bumbershoot,
I'm assuming you are using insteon devices since you are using a scene, this is an older X-10 device.
Sincerely,
Mike
Change line three to "To   Sunrise + 30 minutes (next day)
This --------------------------------------------------------------------------^^^^^^^
I noticed that after I looked at your program, will try that, but it doesn't turn it on either, so must be more too it.
No, it doesn't turn it on because the program was always false as you had it written with "same day".  Your "from time" is after your "to" time.  What you had written will never be true.  ISY works off of triggers.  Your program had two triggers, the from time and the to time.  The trigger initiates the "if" evaluation.  The trigger has nothing to do with it being true or false. So once triggered, it determines true vs false and executes the "then" or "else".  In your case, else every time.
Edited by apostolakisl
@mikesommer
Welcome to the UDI forums!
In addition to the advise given above....
Install a Wait 1 second after each of your X10 commands.
The PLM can confuse signals between X10 and  Insteon  causing one to clobber the other. This should not happen but trial and error has shown differently.
Thanks guys will do those two things and hopefully, it takes care of the problem. Does show status of True now.
Edited by mikesommer
