isy 994i accidently changed port
Hey everybody, any help appreciated. Due to a power outage factory resetting my router I had to reconfig my remote access port forwarding for my isy 994i and when doing, accidently changed the port from 80 when logged into the isy via the java admin console. now the isy finder does not recognize that my isy exists. how do I change my port back? I attempted to type my url into the finding to add it manually and it does not work.
Do you know if you changed the HTTPS port as well? Might try going to https://<isyIP>/admin.jnlp (might get a certificate error, you should be able to get past it).  That won't fix the problem, but might get you access to the admin portal.
Do you know what port you accidentally changed your ISY to? You can change the port on the ISY Launcher to match. Plus what SLD posted above.
It will be a little slower, but you can force access via SSL, get into the console that way, and set the port back
Add an entry to your same IP address, with :443 at the end:
Once you get in, go to configuration and return your http:// port back to 80. Your ISY will appear in the finder once again and you can delete the manual entry in the finder
Paul
Edited by paulbates
Yes I changed it to 94. Funny thing is I set my port forwarding correctly so remote access works now just can't access the controller via console, rookie mistake. I'll try those things when I get home! At work for the day. Appreciate all the help!
paulbates    solution worked! used IP address for my isy plus the port I set it to and it walked right in. Reset http port to 80. reboot isy. now isy finder auto recognizes unit as it should! thank you!
