Blackbird Posted February 21, 2019 Posted February 21, 2019 Can an ELK rule be setup to run an ISY program and run just the Then statement? Thanks
DennisC Posted February 21, 2019 Posted February 21, 2019 5 hours ago, Blackbird said: Can an ELK rule be setup to run an ISY program and run just the Then statement? Thanks One way is to have the Elk rule turn an Output on. Run a program when the Output turns on. You can either have the Elk turn Output off after a time delay, or have the program turn it off.
shannong Posted February 22, 2019 Posted February 22, 2019 I do it the way Dennis suggested. The Elk has a on-timer option which I use so it's turned off right after. I use "phantom" outputs like this for many two-way functions between ISY-Elk to trigger events that aren't part of the integration capabilities.
Blackbird Posted February 22, 2019 Author Posted February 22, 2019 I tried that but you might have seem my other post where I say I cant add outputs to the isy from elk. The refresh topology doesnt seem to work after 5.14
DennisC Posted February 22, 2019 Posted February 22, 2019 I'm not near my system to check, but I seem to remember a check box to allow the phantom output to show?
Blackbird Posted February 22, 2019 Author Posted February 22, 2019 If you find it let me know please. But I dont think the refresh topology button works
TrojanHorse Posted February 22, 2019 Posted February 22, 2019 Are you sure ElkRP isn’t also connected while you try to refresh?Sent from my iPhone using Tapatalk
Blackbird Posted February 22, 2019 Author Posted February 22, 2019 I beleive I tried it with it connected and without. I will confirm but pretty sure rp was off
Blackbird Posted February 22, 2019 Author Posted February 22, 2019 4 hours ago, TrojanHorse said: Are you sure ElkRP isn’t also connected while you try to refresh? Sent from my iPhone using Tapatalk Are you running 5.0.14? Does your refresh work?
Blackbird Posted February 22, 2019 Author Posted February 22, 2019 My bad, I didn't click the "Show" button for the outputs
