February 23, 20197 yr Aeon Labs Key Fob Gen 5, Z-Wave Plus can be included and isy recognizes 8 distinct scenes when pressing 4 buttons each one short and one long button press: Fri 02/22/2019 05:47:08 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x01 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:17 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x02 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:21 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x03 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:28 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x04 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:31 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x05 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:34 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x06 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:37 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x07 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Fri 02/22/2019 05:47:40 PM : [ZWAVE-RX ZW014_1] [2B/01] Scene Activation Set scene=0x08 rr=0xFF ACK,AUTO,EXPLORE From=0x0E Will such a multi button device be supported and in the meantime is there a workaround using this in isy?
February 23, 20197 yr 5 hours ago, CandC said: 4.55.00 and v.5.0.14 Firmware and UI need to match to prevent unusual problems.
February 23, 20197 yr Author z-wave firmware 4.55.00 UI 5.0.14 with firmware 5.0.14... I thought requested was the z-wave firmware... otherwise they do match Edited February 23, 20197 yr by CandC
February 26, 20197 yr You should be able to use programs with the 8 conditions as If triggers... (I’m making an assumption about the device though).Give that a try a let us know. I’m thinking of getting a couple of these myself...
February 27, 20197 yr Author after pairing two nodes are created in isy: ZW 014 Lifeline and ZW014 Remote Control. These two nodes appear in the "if" program drop down menu. The Lifeline gives options on % status and the Remote Control has responding options. Problem is that neither node responds in any way to any button inputs. I wish there was a way to make isy respond to the 8 conditions but reading an old post about the same remote it seems that a custom program has to be written by the isy developers before it is supported in isy... This key fob is very attractive, it is secure and is suitable for door and garage door entry controls...
