Color changing light support coming soon to Google Home
Alexa skills have been using the syntax
Alexa. Set XXX bulb to Red
or
Alexa, Turn on XXX bulb to Red.
The first syntax is more successful. Percentages levels can prefix or follow the colour setting command  but I haven't found a way to compound the parameters into one sentence.
We gave a DLink RGBW bulb and an Echo Dot to my grandson (3 years old) , Christmas 2017 for his bedroom.
Then we gave the sister in law  the same DLink RGBW bulb to use with her GHs May 2018.  Both systems work well using their plug-ins.
ISY Portal should be able to implement this using the same vocals but integer values would need to be substituted for each of the  colours.
On 2/26/2019 at 5:48 PM, MWareman said:
I wonder what the spokens will be to change the color.
Color arrived on a recent update.  Haven't tried it out though.
