Fibaro Smart Implant
Anyone try one of these with the ISY yet?
I'm going to give one a try for my garage door openers.  Very small, cheap, S2 security, 2 INs, 2 Outs, built-in temp sensor...
Just as a Z wave enabled "hub" for 6 DS18b20 temp sensors opens up a lot  of Interesting possibilities!
Edited by glacier991
Typo
Don’t think you can get them yet. Also, how cheap is ‘cheap’. I want some... :P
  • 6 months later...
Bought one to work with the DS18B20 temperature sensors. Plan at the moment is to hook up two sensors to the pipes leading to the showers. Will trigger the bathroom fan to run and shutdown.
First attempt to get it to work on my desk next to me didn't go well. No temperature other than the internal. Wired up correctly. Ok read the instructions....
Attach the temperature sensors, then include the unit to the ISY. Worked like a charm for the single sensor I have attached. I suspect adding more sensors will require excluding and including.
Will update as I work toward the install.
I am trying to get  a Fibaro FGBS222 running with 4 DS18b20 temperature probes.   I've successfully included the unit to the ISY but I dont see 4 temperatures.  Any clues?
Got it working with 4 sensors.   The hair-like wires that come out of the Implant are difficult to work with.  I had a bad connection going the the 4 sensors.  After excude and include it looks great.  ZW004.7 is the device internal temp, and 4.8 thru 4.11 are the 4 temp probes.   This is going to be a very useful device!!!!
  • 11 months later...
Back in September of last year I reported I was using one of these smart implants. It worked well for a while but then began not working.
I spent a long time trying to figure out why it stopped functioning. I had added a temp probe (DS18B20). It wouldn't report updates without me manually querying it. I tried replacing the temperature probe. That send me off in the wrong direction. Apparently these are well known to have many fakes being produced. Only a small percentage can be relied to work out of the box. Once I'd figured that out, I bought another smart implant with better temp probes. Well it doesn't work either.
I've come to the conclusion that at somepoint an upgrade to the ISY changed how these report (or don't report). Are others experincing this problem? Parameters 67 and 68 change how the unit reports and I've changed those many times on both units I now have. Still the ISY will not accept the updates to the temp probe.
Is there a fix? What am I missing??
I'm running FW 5.3.0
  • 3 weeks later...
I have the exact same issue.
No automatic updates, I have to Query it for it to update temperature.
I also run FW 5.3.0, and have one DS18B20 attached to it.
