2476S SwitchLinc Relay with Beeper.
For those that have access to the Insteon Code Area.
There is a new Version of the 2476S SwitchLinc relay that now has a beeper.
There are changes to things that maybe of interest to some. Like there are NO X10 Scenes just one Primary X10 Address.
The Quick Start Guide on the sales page has also been updated. Rev >5.0
also have a sense input and updated current rating of 15 Amps up from 13 Amps. The Load is now a dry contact set so you can switch low voltage loads if you so desire or wire to the Line and use as a standard 120 volt switch.
