Email sends when I execute Then but not when program triggers
I have a program:
IF MOTION_DETECTED THEN
  Notification
  Repeat 3 times
      Light fast on
      Wait 2 seconds
      Light fast off
ELSE
END
Notification is sent and the light blinks when I run the THEN
But when I actually trigger the MOTION the light blinks as expected but the notification is not sent!
Any ideas?
TIA
We need to see the exact syntax for the program. There are various methods of detecting events.
Right click on the program title in the program tree and select copy to clipboard. Then past it here.
What MS device are you using?
<?xml version="1.0" ?><triggers><d2d><trigger><id>13</id><name>Motion Org</name><parent>1</parent><if><and /><status id ="ST" node="36 93 30 1" op="IS"><val uom="51" prec="0">100</val></status></if><then><notify content="1">2</notify><repeat><for><times>3</times></for></repeat><cmd id="DFON" node="26 D7 2E 1"></cmd><wait><seconds>2</seconds></wait><cmd id="DFOF" node="26 D7 2E 1"></cmd></then><else></else><comment></comment></trigger></d2d></triggers>
2842-222. 4814 Rev 2.6
Thank You
