New Controller Question
Hi,
I read in a post somewhere here today that somebody was asking for help because he just purchased a new ISY Controller because his old one wasn't working correctly.
He said he wanted to downgrade from 5 to 4 (firmware).
He said the new controllers are being shipped out with the new version 5 of the firmware.
So my question is this:
Is it true if I order a new ISY it will come without version 5 firmware?
I have been holding back from upgrading my ISY from 4 to 5 because it's a lot of work making sure the uograde converted all my programming correctly.
So if I purchase a new ISY and it comes with version 5 of the firmware then I could slowly move all of my Automation from the old controller to the new one.
After everything is switched I can then do an upgrade to the old controller to version 5 and then store it as a backup controller should anything happen to the new controller.
(Plus it puts some money into Universal Devices coffers for all their hard work over the years!)
I believe I have the Z-Wave version with IR
Its a Pro IR with Z-Wave.
I think that's what I have.
Rob
  • 3 months later...
@rlanza1054,
What's the model number on the bottom of your ISY?
Attached is a picture of the bottom label of my ISY.
I'm still interested in obtaining a new ISY with the new 5.x firmware rather than upgrading my existing ISY.
I just need to know which one I should order.
And if I order from Amazon can I assume I will get version 5.x firmware or should I order it directly from you. Universal Devices?
Sent from my SM-G975U1 using Tapatalk
I personally would get it from UDI directly. Some of my Amazon purchases have been an older version. Especially from  an Amazon Merchant. If Amazon gets them sent to you directly from Smarthome. They don't have any version ISY994i models in stock.
That model number is a ZWave and IR  PRO ISY994i
https://www.universal-devices.com/product/isy994i-zw-ir-pro/
Edited by Brian H
Add information
