What uses the 132 memory size?
My ISY reports that's it's somehow gone over the limit (90) for the 132 sized memory allocation. What's that memory used for?
I'm trying to debug a weird issue where some programs are no longer running - "fixed" it by rebooting the ISY and am monitoring the memory now to try to identify the root cause... any hints/tips appreciated.
I'm running 5.0.15A (both firmware and UI) on a 994i PRO.
I observed it via the 'sm' command using telnet. It is back in the same state now - see below.
The most significant changes I've made recently have been to add logging via the internal webserver (which is an amazing feature, btw) - could that be related?
Thank you Michel - super quick insights as always. I've removed most of the notifs (they were all writing to a webserver file rather than sending emails) and things are back to normal.
