Run as service on RPi
Is it possible to have this setup to run as a service in Linux on Debian? Would certainly make some things easier on my end.
Yes, it is.  I believe the install script inserts a command into the '/etc/rc.local' file to start NodeLink.  I use 'systemctl' to start/stop/restart NodeLink on an RPi running Stretch (which is a Debian variant).
Here's what my 'nodelink.service' file looks link in '/etc/systemd/system':
[UNIT]
Description=NodeLink Server
Documentation=http://automationshack.com/nodelink.html
Requires=network-online.target
After=network-online.target
[Service]
Type=simple
ExecStartPre=/bin/sleep 10
ExecStart=/usr/bin/mono /home/pi/Nodelink/NodeLink.exe
Restart=always
User=pi
[Install]
WantedBy=multi-user.target
Here's a post I wrote describing this technique for managing a WeatherFlow node server some time ago.  The process for NodeLink is essentially identical, just substitute 'nodelink' for 'weatherflow' and use the 'nodelink.service' file above instead of the 'weatherflow.service' file described in the post.
I copied your nodelink.service file and placed it where you stated. I did have to change the ExecStart location, as the install script for NodeLink apparently installs to /home/pi/node/NodeLink.exe. When I issue the command sudo systemctl status nodelink. I get the following:
 nodelink.service
   Loaded: loaded (/etc/systemd/system/nodelink.service; enabled; vendor preset: enabled)
   Active: activating (start-pre) since Mon 2019-08-05 06:14:11 PDT; 4s ago
  Process: 3011 ExecStart=/usr/bin/mono /home/pi/node/NodeLink.exe (code=exited, status=1/FAILURE)
 Main PID: 3011 (code=exited, status=1/FAILURE); Control PID: 3020 (sleep)
    Tasks: 1 (limit: 19660)
   CGroup: /system.slice/nodelink.service
           └─control
             └─3020 /bin/sleep 10
Aug 05 06:14:11 polyglot systemd[1]: nodelink.service: Service hold-off time over, scheduling restart.
Aug 05 06:14:11 polyglot systemd[1]: Stopped nodelink.service.
Aug 05 06:14:11 polyglot systemd[1]: Starting nodelink.service...
And this keeps repeating over and over... I am likely missing something REALLY simple here.
Did you issue the command: 'sudo systemctl enable nodelink' prior to starting it?
EDIT: Did you also edit the "User=pi" line of the 'nodelink.system' file to reflect the correct username that you used to install Nodelink?
Edited by Bumbershoot
Yes and yes.
The user I created in Debian 9 was named 'pi'
So I just ran the command /usr/bin/mono /home/pi/node/NodeLink.exe and I get the following:
Unhandled Exception:
System.UnauthorizedAccessException: Access to the path "/home/pi/node/config-bak.xml" or "/home/pi/node/config.xml" is denied.
  at System.IO.File.Copy (System.String sourceFileName, System.String destFileName, System.Boolean overwrite) [0x001c4] in <8f2c484307284b51944a1a13a14c0266>:0
  at NodeLink.xmlConfig.LoadXML () [0x000c3] in <b05e769338f042a5be8cbddc43419363>:0
  at j.j () [0x0027a] in <b05e769338f042a5be8cbddc43419363>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.UnauthorizedAccessException: Access to the path "/home/pi/node/config-bak.xml" or "/home/pi/node/config.xml" is denied.
I am guessing I need to change the permissions. So I did a chmod -R 777 to /home/pi/node.
Then I ran sudo systemctl enable nodelink, then sudo systemctl start nodelink. That seems to have done the trick. It would likely be a good thing to have the service run as part of the install script.
I believe the install script does it differently by inserting a command into '/etc/rc.local' instead of using the systemd framework.  Check to see if you have NodeLink specified to start in '/etc/rc.local'.  Either way, I'm glad you got it going.  NodeLink is a terrific bit of software.
Yes it is, for the last long while I have been running it in Windows, and it would get closed and had trouble restarting it at times during reboots. So with Polyglot, (and the upcoming Polisy), I decided to set up a Hyper-V virtual machine for Polyglot and figured it would be a good idea to get NodeLink on the same VM. Thank you for your help. (Hyper-V should restart the machines automatically on reboots so that should be helpful in keeping all of this working.) Time will tell though.
