MarkJames Posted August 21, 2019 Posted August 21, 2019 I'm not sure what changed but when I start ElkRP I now get dialog box pop up that says ' Windows reports that the selected device does not exist or has been removed. You must reinstall it or select another device to use. This error may occur because you recently enabled a wireless broadband card. In that case just ignore this message'. I connect ok but my triggers based on Elk M1 zone violations have started lagging. I'm not sure if the two are related but either way I'm curious what the dialog means. Thanks in advance.
Michel Kohanim Posted August 22, 2019 Posted August 22, 2019 @MarkJames, Please contact ELK Tech Support. With kind regards, Michel
MarkJames Posted August 22, 2019 Author Posted August 22, 2019 Actually I think it may be resolved. I'm just waiting a bit to be sure. It looks like it may have been a network problem [edit] Yes - resolved. Turned out to be a network connectivity issue. Thanks for the help.
