Venstar Showing up as Light
I am really struggling getting my Venstar to show up correctly. I previously had my Venstar thermostat installed via Nodelink and showing up correctly, however I was experiencing polyglot issues so I restored to ISY firmware 4.7.3 and a previous backup. I then upgraded from 4.7.3 to 5.0.15A in order to start from scratch all my node servers. I have been having issues since I restarted with 5.0.15A. Not sure if this is a Nodelink or an ISY issue but I am definitely stuck.
I have installed Nodelink and configured my 2 x Venstar thermostats. Nodelink can see my thermostats and report their settings. When I try to add the thermostat to ISY via the nodeserver, the thermostats show up as lights (see attached picture).
My error log on the Nodelink server is below. The entry that concerns me most is: " ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/4/download/EDITOR/I_EDIT.XML" There are several of these "forbidden entries." Are they part of the problem?
Really appreciate anyone's help!
2019-09-04 06:50:51 - ISY NodeLink Server v0.9.34 started
2019-09-04 06:50:51 - OS: Linux server 4.19.0-0.bpo.5-amd64 #1 SMP Debian 4.19.37-4~bpo9+1 (2019-06-19) x86_64 GNU/Linux
2019-09-04 06:50:51 - Mono version: 6.0.0.313 (tarball Sun Jul 14 09:55:10 UTC 2019)
2019-09-04 06:50:51 - Web config server started (http://192.168.1.5:8090)
2019-09-04 06:50:51 - ISY resolved to 192.168.1.40 (5.0.15A)
2019-09-04 06:50:51 - ISY Send: Node Server request sent
2019-09-04 06:50:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><connections all="true" max="25"><connection profile="4" type="network" enabled="true"><name>isylink</name><ssl>false</ssl><sni>false</sni><port>8090</port><timeout>10</timeout><isyusernum>0</isyusernum><ip>192.168.1.40</ip><baseurl>isylink</baseurl><nsuser></nsuser></connection></connections> (profiles/ns/0/connection)
2019-09-04 06:50:51 - ISY Node Server config detected (profile 4)
2019-09-04 06:50:51 - ISY Send: Node list request sent
2019-09-04 06:50:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><nodes><root></root><folder flag="0"><address>54555</address><name>Kitchen</name></folder><folder flag="0"><address>15464</address><name>Master Bedroom</name></folder><folder flag="0"><address>8886</address><name>Living Room</name></folder><folder flag="0"><address>2064</address><name>Basement</name></folder><folder flag="0"><address>39981</address><name>Kids</name></folder><folder flag="0"><address>11963</address><name>Playroom</name></folder><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>46 8F 95 1</address><name>Master Bedroom Overhead Light</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 8F 95 1</pnode><ELK_ID>A02</ELK_ID><property id="ST" value="33" formatted="13%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 89 13 1</address><name>Master Bathroom- Fan</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 89 13 1</pnode><ELK_ID>A03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 8A 44 1</address><name>Master Bathroom Shower Light</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 8A 44 1</pnode><ELK_ID>A04</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 87 8B 1</address><name>Master Bathroom Vanity Lights</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 87 8B 1</pnode><ELK_ID>A05</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>46 92 48 1</address><name>Playroom Dimmer</name><parent type="3">11963</parent><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 92 48 1</pnode><ELK_ID>A06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 89 55 1</address><name>Playroom Remote</name><parent type="3">11963</parent><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 89 55 1</pnode><ELK_ID>A07</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 89 82 1</address><name>Front Porch</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 89 82 1</pnode><ELK_ID>A08</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 80 1 1</address><name>Living Room Overhead Lights</name><type>1.25.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 80 1 1</pnode><ELK_ID>A09</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>23 C8 6C 1</address><name>Breakfast Nook Overhead Light</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>23 C8 6C 1</pnode><ELK_ID>A10</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 7F BB 1</address><name>Kitchen Overhead Lights</name><type>1.25.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 7F BB 1</pnode><ELK_ID>A11</ELK_ID><property id="ST" value="153" formatted="60%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>20 CA B7 1</address><name>Kitchen Counter Lights</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>20 CA B7 1</pnode><ELK_ID>A12</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 7A AE 1</address><name>Kitchen Island Lights</name><type>1.25.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 7A AE 1</pnode><ELK_ID>A13</ELK_ID><property id="ST" value="102" formatted="40%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 7F 6F 1</address><name>Kitchen Remote by Pantry</name><type>1.25.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 7F 6F 1</pnode><ELK_ID>A14</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 89 EA 1</address><name>Dining Room Remote</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 89 EA 1</pnode><ELK_ID>A15</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 49 38 1</address><name>Diane Bedside Light</name><type>1.0.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 49 38 1</pnode><ELK_ID>A16</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 E6 C 1</address><name>Living Room Floor Lamp Right</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 E6 C 1</pnode><ELK_ID>B01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 89 46 1</address><name>Garage Outside Lights</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 89 46 1</pnode><ELK_ID>B02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer"><address>16 6E 76 1</address><name>Master Bath Controller-1</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>16 6E 76 1</pnode><ELK_ID>B06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>16 6E 76 3</address><name>Master Bath Controller-A</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>16 6E 76 1</pnode><ELK_ID>B07</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>16 6E 76 4</address><name>Master Bath Controller-B</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>16 6E 76 1</pnode><ELK_ID>B08</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>16 6E 76 5</address><name>Master Bath Controller-C</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>16 6E 76 1</pnode><ELK_ID>B09</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>16 6E 76 6</address><name>Master Bath Controller-D</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>16 6E 76 1</pnode><ELK_ID>B10</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 49 70 1</address><name>Living Room Floor Lamp Left</name><type>1.0.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 49 70 1</pnode><ELK_ID>C03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer_ADV"><address>46 FC 64 1</address><name>Allen Bedside Controller..1</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 64 1</pnode><ELK_ID>C04</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 64 3</address><name>Allen Bedside Controller..A</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 64 1</pnode><ELK_ID>C05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 64 4</address><name>Allen Bedside Controller..B</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 64 1</pnode><ELK_ID>C06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 64 5</address><name>Allen Bedside Controller..C</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 64 1</pnode><ELK_ID>C07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 64 6</address><name>Allen Bedside Controller..D</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 64 1</pnode><ELK_ID>C08</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 4C 8 1</address><name>Allen Bedside Light</name><type>1.0.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 4C 8 1</pnode><ELK_ID>C09</ELK_ID><property id="ST" value="102" formatted="40%" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer_ADV"><address>46 FC 53 1</address><name>Diane Controller-1</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 53 1</pnode><ELK_ID>C13</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 53 3</address><name>Diane Controller-A</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 53 1</pnode><ELK_ID>C14</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 53 4</address><name>Diane Controller-B</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 53 1</pnode><ELK_ID>C15</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 53 5</address><name>Diane Controller-C</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 53 1</pnode><ELK_ID>C16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>46 FC 53 6</address><name>Diane Controller-D</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 FC 53 1</pnode><ELK_ID>D01</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 49 22 1</address><name>Little Disk Light</name><type>1.0.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 49 22 1</pnode><ELK_ID>D02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>46 4A 4C 1</address><name>Master Bathroom Toilet Light</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 4A 4C 1</pnode><ELK_ID>D04</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>44 37 D 1</address><name>Daniel Overhead Light</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 37 D 1</pnode><ELK_ID>D05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>15 49 18 1</address><name>Daniel Chair Lamp</name><type>1.0.56.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 49 18 1</pnode><ELK_ID>D06</ELK_ID><property id="ST" value="26" formatted="10%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>44 3B E8 1</address><name>Andrew Overhead Light</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 3B E8 1</pnode><ELK_ID>D07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>15 F7 24 1</address><name>Raspberry Pi</name><type>2.9.56.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 F7 24 1</pnode><ELK_ID>D08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="VenstarF" nls="140V"><address>n004_ven2</address><name>Venstar</name><family instance="4">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n004_ven2</pnode><ELK_ID>D12</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 E1 AA 1</address><name>Living Room Chair Light</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 E1 AA 1</pnode><ELK_ID>D16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>46 8A B5 1</address><name>Basement Hallway Dimmer</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 8A B5 1</pnode><ELK_ID>E01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer"><address>15 A0 3A 1</address><name>Basement Light Keypad-.1</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 A0 3A 1</pnode><ELK_ID>E02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>15 A0 3A 3</address><name>Basement Light Keypad-.A</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 A0 3A 1</pnode><ELK_ID>E03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>15 A0 3A 4</address><name>Basement Light Keypad-.B</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 A0 3A 1</pnode><ELK_ID>E04</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>15 A0 3A 5</address><name>Basement Light Keypad-.C</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 A0 3A 1</pnode><ELK_ID>E05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton"><address>15 A0 3A 6</address><name>Basement Light Keypad-.D</name><type>1.27.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>15 A0 3A 1</pnode><ELK_ID>E06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>45 88 6F 1</address><name>Basement Hallway Remote</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>45 88 6F 1</pnode><ELK_ID>E07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>44 38 D1 1</address><name>Basement Light Remote</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 38 D1 1</pnode><ELK_ID>E08</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="BinaryControl"><address>19 90 90 1</address><name>Sump Pump</name><type>7.9.48.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>19 90 90 1</pnode><ELK_ID>E15</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>21 90 5B 1</address><name>Diane Office Desk</name><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>21 90 5B 1</pnode><ELK_ID>E16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>21 87 A2 1</address><name>Diane Office Chair Light</name><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>21 87 A2 1</pnode><ELK_ID>F01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>44 36 50 1</address><name>Diane Office Overhead Light</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 36 50 1</pnode><ELK_ID>F03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer_ADV"><address>48 A9 E1 1</address><name>Andrew Controller..1</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A9 E1 1</pnode><ELK_ID>F04</ELK_ID><property id="ST" value="112" formatted="44%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>48 A9 E1 3</address><name>Andrew Controller..A</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A9 E1 1</pnode><ELK_ID>F05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>48 A9 E1 4</address><name>Andrew Controller..B</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A9 E1 1</pnode><ELK_ID>F06</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>48 A9 E1 5</address><name>Andrew Controller..C</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A9 E1 1</pnode><ELK_ID>F07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>48 A9 E1 6</address><name>Andrew Controller..D</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A9 E1 1</pnode><ELK_ID>F08</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>21 8A B3 1</address><name>Andrew Lamp</name><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>21 8A B3 1</pnode><ELK_ID>F09</ELK_ID><property id="ST" value="112" formatted="44%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 E B6 1</address><name>Diane Office Torchier</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 E B6 1</pnode><ELK_ID>F16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 26 5 1</address><name>Master Bedroom Dresser Lamp</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 26 5 1</pnode><ELK_ID>G01</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>3B 3 31 1</address><name>Master Bedroom Picture Light-</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3B 3 31 1</pnode><ELK_ID>G02</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>23 C C7 1</address><name>Outdoor Christmas Lights</name><type>2.56.66.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>23 C C7 1</pnode><ELK_ID>G03</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="BinaryControl_ADV"><address>44 D6 EE 1</address><name>Garage Door Sensor</name><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 D6 EE 1</pnode><ELK_ID>G05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="RelayLampOnly"><address>44 D6 EE 2</address><name>44.D6.EE-Relay</name><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>44 D6 EE 1</pnode><ELK_ID>G06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="BinaryAlarm"><address>13 E3 FF 1</address><name>Pantry Door Sensor</name><parent type="3">54555</parent><type>16.2.40.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>13 E3 FF 1</pnode><ELK_ID>G07</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="BinaryAlarm"><address>13 E3 FF 2</address><name>Pantry Door Sensor- Closed</name><parent type="1">13 E3 FF 1</parent><type>16.2.40.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>13 E3 FF 1</pnode><ELK_ID>G08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="VenstarSensorF" nls="140VS"><address>n004_ven2_s00</address><name>Outdoor</name><family instance="4">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n004_ven2</pnode><ELK_ID>G09</ELK_ID></node><node flag="128" nodeDefId="VenstarF" nls="140V"><address>n004_ven1</address><name>Venstar</name><family instance="4">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n004_ven1</pnode><ELK_ID>G10</ELK_ID></node><node flag="0" nodeDefId="VenstarSensorF" nls="140VS"><address>n004_ven1_s00</address><name>Space Temp</name><family instance="4">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n004_ven1</pnode><ELK_ID>G11</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>48 A C4 1</address><name>Daniel Bedside Remote</name><parent type="3">39981</parent><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>48 A C4 1</pnode><ELK_ID>H06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><group flag="12" nodeDefId="InsteonDimmer"><address>00:21:b9:00:fb:d0</address><name>ISY</name><family>6</family><members><link type="0">00:21:b9:00:fb:d0</link><link type="0">ADR0001</link><link type="0">46 8F 95 1</link><link type="0">45 89 13 1</link><link type="0">45 8A 44 1</link><link type="0">45 87 8B 1</link><link type="0">46 92 48 1</link><link type="0">45 89 55 1</link><link type="0">45 89 82 1</link><link type="0">15 80 1 1</link><link type="0">23 C8 6C 1</link><link type="0">15 7F BB 1</link><link type="0">20 CA B7 1</link><link type="0">15 7A AE 1</link><link type="0">15 7F 6F 1</link><link type="0">45 89 EA 1</link><link type="0">15 49 38 1</link><link type="0">47 E6 C 1</link><link type="0">45 89 46 1</link><link type="0">62974</link><link type="0">6432</link><link type="0">42461</link><link type="0">16 6E 76 1</link><link type="0">16 6E 76 3</link><link type="0">16 6E 76 4</link><link type="0">16 6E 76 5</link><link type="0">16 6E 76 6</link><link type="0">54555</link><link type="0">15464</link><link type="0">62369</link><link type="0">36698</link><link type="0">6159</link><link type="0">627</link><link type="0">452</link><link type="0">8886</link><link type="0">15 49 70 1</link><link type="0">46 FC 64 1</link><link type="0">46 FC 64 3</link><link type="0">46 FC 64 4</link><link type="0">46 FC 64 5</link><link type="0">46 FC 64 6</link><link type="0">15 4C 8 1</link><link type="0">22571</link><link type="0">22841</link><link type="0">17166</link><link type="0">46 FC 53 1</link><link type="0">46 FC 53 3</link><link type="0">46 FC 53 4</link><link type="0">46 FC 53 5</link><link type="0">46 FC 53 6</link><link type="0">15 49 22 1</link><link type="0">41241</link><link type="0">46 4A 4C 1</link><link type="0">44 37 D 1</link><link type="0">15 49 18 1</link><link type="0">44 3B E8 1</link><link type="0">15 F7 24 1</link><link type="0">51135</link><link type="0">5803</link><link type="0">56251</link><link type="0">n004_ven2</link><link type="0">32517</link><link type="0">14514</link><link type="0">17160</link><link type="0">47 E1 AA 1</link><link type="0">46 8A B5 1</link><link type="0">15 A0 3A 1</link><link type="0">15 A0 3A 3</link><link type="0">15 A0 3A 4</link><link type="0">15 A0 3A 5</link><link type="0">15 A0 3A 6</link><link type="0">45 88 6F 1</link><link type="0">44 38 D1 1</link><link type="0">30010</link><link type="0">62685</link><link type="0">2064</link><link type="0">7004</link><link type="0">3874</link><link type="0">61013</link><link type="0">19 90 90 1</link><link type="0">21 90 5B 1</link><link type="0">21 87 A2 1</link><link type="0">38569</link><link type="0">44 36 50 1</link><link type="0">48 A9 E1 1</link><link type="0">48 A9 E1 3</link><link type="0">48 A9 E1 4</link><link type="0">48 A9 E1 5</link><link type="0">48 A9 E1 6</link><link type="0">21 8A B3 1</link><link type="0">454</link><link type="0">33484</link><link type="0">39981</link><link type="0">590</link><link type="0">22482</link><link type="0">52308</link><link type="0">47 E B6 1</link><link type="0">47 26 5 1</link><link type="0">3B 3 31 1</link><link type="0">23 C C7 1</link><link type="0">4972</link><link type="0">44 D6 EE 1</link><link type="0">44 D6 EE 2</link><link type="0">13 E3 FF 1</link><link type="0">13 E3 FF 2</link><link type="0">n004_ven2_s00</link><link type="0">n004_ven1</link><link type="0">n004_ven1_s00</link><link type="0">11963</link><link type="0">48 A C4 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>ADR0001</address><name>Auto DR</name><family>6</family><deviceGroup>16</deviceGroup><pnode>ADR0001</pnode><ELK_ID>A01</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>62974</address><name>Driveway Lights</name><family>6</family><deviceGroup>17</deviceGroup><pnode>62974</pnode><ELK_ID>B03</ELK_ID><members><link type="0">45 89 82 1</link><link type="0">45 89 46 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>6432</address><name>Kitchen</name><family>6</family><parent type="3">54555</parent><deviceGroup>18</deviceGroup><pnode>6432</pnode><ELK_ID>B04</ELK_ID><members><link type="16">15 7F BB 1</link><link type="16">20 CA B7 1</link><link type="16">15 7A AE 1</link><link type="16">15 7F 6F 1</link><link type="16">45 89 EA 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>42461</address><name>Living Room</name><family>6</family><parent type="3">8886</parent><deviceGroup>19</deviceGroup><pnode>42461</pnode><ELK_ID>B05</ELK_ID><members><link type="16">15 80 1 1</link><link type="0">47 E6 C 1</link><link type="0">15 49 70 1</link><link type="0">47 E1 AA 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>62369</address><name>Master Bath Fan On</name><family>6</family><parent type="3">15464</parent><deviceGroup>20</deviceGroup><pnode>62369</pnode><ELK_ID>B13</ELK_ID><members><link type="0">45 89 13 1</link><link type="16">16 6E 76 3</link><link type="0">16 6E 76 4</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>36698</address><name>Master Bath Shower Light On</name><family>6</family><parent type="3">15464</parent><deviceGroup>21</deviceGroup><pnode>36698</pnode><ELK_ID>B14</ELK_ID><members><link type="0">45 8A 44 1</link><link type="16">16 6E 76 5</link><link type="0">16 6E 76 6</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>6159</address><name>Master Bath Vanity On</name><family>6</family><parent type="3">15464</parent><deviceGroup>22</deviceGroup><pnode>6159</pnode><ELK_ID>B15</ELK_ID><members><link type="0">45 87 8B 1</link><link type="16">16 6E 76 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>627</address><name>Master Bath Fan Off</name><family>6</family><parent type="3">15464</parent><deviceGroup>23</deviceGroup><pnode>627</pnode><ELK_ID>B16</ELK_ID><members><link type="0">45 89 13 1</link><link type="0">16 6E 76 3</link><link type="16">16 6E 76 4</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>452</address><name>Master Bath Shower Light Off</name><family>6</family><parent type="3">15464</parent><deviceGroup>24</deviceGroup><pnode>452</pnode><ELK_ID>C01</ELK_ID><members><link type="0">45 8A 44 1</link><link type="0">16 6E 76 5</link><link type="16">16 6E 76 6</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>22571</address><name>Allen Bedside On</name><family>6</family><parent type="3">15464</parent><deviceGroup>26</deviceGroup><pnode>22571</pnode><ELK_ID>C10</ELK_ID><members><link type="16">46 FC 64 1</link><link type="0">15 4C 8 1</link><link type="16">46 FC 53 3</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>22841</address><name>Master Bedroom</name><family>6</family><parent type="3">15464</parent><deviceGroup>27</deviceGroup><pnode>22841</pnode><ELK_ID>C11</ELK_ID><members><link type="16">46 8F 95 1</link><link type="0">15 49 38 1</link><link type="0">15 4C 8 1</link><link type="0">15 49 22 1</link><link type="0">47 26 5 1</link><link type="0">3B 3 31 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>17166</address><name>Diane Bedside On</name><family>6</family><parent type="3">15464</parent><deviceGroup>28</deviceGroup><pnode>17166</pnode><ELK_ID>C12</ELK_ID><members><link type="0">15 49 38 1</link><link type="16">46 FC 64 3</link><link type="16">46 FC 53 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>41241</address><name>Room Off minus bedside lights</name><family>6</family><parent type="3">15464</parent><deviceGroup>25</deviceGroup><pnode>41241</pnode><ELK_ID>D03</ELK_ID><members><link type="0">46 8F 95 1</link><link type="16">46 FC 64 5</link><link type="16">46 FC 53 5</link><link type="0">15 49 22 1</link><link type="0">47 26 5 1</link><link type="0">3B 3 31 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>51135</address><name>Andrew Sleep Mode</name><family>6</family><parent type="3">39981</parent><deviceGroup>44</deviceGroup><pnode>51135</pnode><ELK_ID>D09</ELK_ID><members><link type="0">44 3B E8 1</link><link type="0">21 8A B3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>5803</address><name>Daniel Sleep Mode</name><family>6</family><parent type="3">39981</parent><deviceGroup>45</deviceGroup><pnode>5803</pnode><ELK_ID>D10</ELK_ID><members><link type="0">44 37 D 1</link><link type="0">15 49 18 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>56251</address><name>Daniel Reading Mode</name><family>6</family><parent type="3">39981</parent><deviceGroup>46</deviceGroup><pnode>56251</pnode><ELK_ID>D11</ELK_ID><members><link type="0">44 37 D 1</link><link type="0">15 49 18 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>32517</address><name>Daniel Lights</name><family>6</family><parent type="3">39981</parent><deviceGroup>29</deviceGroup><pnode>32517</pnode><ELK_ID>D13</ELK_ID><members><link type="16">46 FC 64 4</link><link type="16">46 FC 53 4</link><link type="16">44 37 D 1</link><link type="0">15 49 18 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>14514</address><name>Daniel Chair Lamp Scene</name><family>6</family><parent type="3">39981</parent><deviceGroup>30</deviceGroup><pnode>14514</pnode><ELK_ID>D14</ELK_ID><members><link type="0">15 49 18 1</link><link type="16">48 A C4 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>17160</address><name>Master Bathroom</name><family>6</family><parent type="3">15464</parent><deviceGroup>31</deviceGroup><pnode>17160</pnode><ELK_ID>D15</ELK_ID><members><link type="16">46 4A 4C 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>30010</address><name>Basement Overhead</name><family>6</family><parent type="3">2064</parent><deviceGroup>32</deviceGroup><pnode>30010</pnode><ELK_ID>E09</ELK_ID><members><link type="16">15 A0 3A 1</link><link type="16">44 38 D1 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>62685</address><name>Basement Hallway</name><family>6</family><parent type="3">2064</parent><deviceGroup>33</deviceGroup><pnode>62685</pnode><ELK_ID>E10</ELK_ID><members><link type="16">46 8A B5 1</link><link type="16">45 88 6F 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>7004</address><name>Goodnight</name><family>6</family><deviceGroup>34</deviceGroup><pnode>7004</pnode><ELK_ID>E12</ELK_ID><members><link type="0">46 92 48 1</link><link type="0">15 80 1 1</link><link type="0">23 C8 6C 1</link><link type="0">15 7F BB 1</link><link type="0">20 CA B7 1</link><link type="0">15 7A AE 1</link><link type="0">47 E6 C 1</link><link type="0">15 49 70 1</link><link type="0">47 E1 AA 1</link><link type="0">46 8A B5 1</link><link type="0">15 A0 3A 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>3874</address><name>All Off</name><family>6</family><deviceGroup>35</deviceGroup><pnode>3874</pnode><ELK_ID>E13</ELK_ID><members><link type="0">46 8F 95 1</link><link type="0">45 89 13 1</link><link type="0">45 8A 44 1</link><link type="0">45 87 8B 1</link><link type="0">46 92 48 1</link><link type="0">15 80 1 1</link><link type="0">23 C8 6C 1</link><link type="0">15 7F BB 1</link><link type="0">20 CA B7 1</link><link type="0">15 7A AE 1</link><link type="0">15 49 38 1</link><link type="0">47 E6 C 1</link><link type="0">15 49 70 1</link><link type="0">46 FC 64 1</link><link type="0">15 4C 8 1</link><link type="0">15 49 22 1</link><link type="0">46 4A 4C 1</link><link type="0">44 37 D 1</link><link type="0">15 49 18 1</link><link type="0">44 3B E8 1</link><link type="0">47 E1 AA 1</link><link type="0">46 8A B5 1</link><link type="0">15 A0 3A 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>61013</address><name>Daniel Lights Off</name><family>6</family><parent type="3">15464</parent><deviceGroup>36</deviceGroup><pnode>61013</pnode><ELK_ID>E14</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>38569</address><name>Diane Office</name><family>6</family><deviceGroup>37</deviceGroup><pnode>38569</pnode><ELK_ID>F02</ELK_ID><members><link type="0">21 90 5B 1</link><link type="0">21 87 A2 1</link><link type="16">44 36 50 1</link><link type="0">47 E B6 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>454</address><name>Andrew Lights</name><family>6</family><parent type="3">39981</parent><deviceGroup>38</deviceGroup><pnode>454</pnode><ELK_ID>F10</ELK_ID><members><link type="16">46 FC 64 6</link><link type="16">46 FC 53 6</link><link type="16">44 3B E8 1</link><link type="0">21 8A B3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>33484</address><name>Andrew Chair Lamp Scene</name><family>6</family><parent type="3">39981</parent><deviceGroup>39</deviceGroup><pnode>33484</pnode><ELK_ID>F11</ELK_ID><members><link type="16">48 A9 E1 1</link><link type="0">21 8A B3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>590</address><name>Andrew Overhead</name><family>6</family><parent type="3">39981</parent><deviceGroup>40</deviceGroup><pnode>590</pnode><ELK_ID>F13</ELK_ID><members><link type="0">44 3B E8 1</link><link type="16">48 A9 E1 3</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>22482</address><name>Daniel Overhead Lamp</name><family>6</family><parent type="3">39981</parent><deviceGroup>41</deviceGroup><pnode>22482</pnode><ELK_ID>F14</ELK_ID><members><link type="0">44 37 D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>52308</address><name>Family TV Scene</name><family>6</family><parent type="3">8886</parent><deviceGroup>42</deviceGroup><pnode>52308</pnode><ELK_ID>F15</ELK_ID><members><link type="0">15 80 1 1</link><link type="0">47 E6 C 1</link><link type="0">15 49 70 1</link><link type="0">47 E1 AA 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>4972</address><name>Driveway Christmas</name><family>6</family><deviceGroup>43</deviceGroup><pnode>4972</pnode><ELK_ID>G04</ELK_ID><members><link type="0">45 89 82 1</link><link type="0">45 89 46 1</link><link type="0">23 C C7 1</link></members></group></nodes> (nodes)
2019-09-04 06:50:52 - ISY Warning: Duplicate node names exist on the ISY (Venstar)
2019-09-04 06:50:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="false"><status>403</status><reason code="1205" /></RestResponse> (profiles/family/10/profile/4/download/EDITOR/I_EDIT.XML)
2019-09-04 06:50:52 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/4/download/EDITOR/I_EDIT.XML)
2019-09-04 06:50:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="false"><status>403</status><reason code="1205" /></RestResponse> (profiles/family/10/profile/4/download/NODEDEF/I_NDEFS.XML)
2019-09-04 06:50:52 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/4/download/NODEDEF/I_NDEFS.XML)
2019-09-04 06:50:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="false"><status>403</status><reason code="1205" /></RestResponse> (profiles/family/10/profile/4/download/NLS/EN_US.TXT)
2019-09-04 06:50:52 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/4/download/NLS/EN_US.TXT)
2019-09-04 06:50:52 - Warning: Node definitions need updating in ISY, see NodeLink's Devices page
2019-09-04 06:50:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><climate enabled="true" locationId="MID_AS365" rss="http://wx.hamweather.com/?pands=MID_AS365" lastUpdatedTS="2019/09/04 06:50:59"><Temperature>71 °F</Temperature><Temperature_High>74 °F</Temperature_High><Temperature_Low>70 °F</Temperature_Low><Feels_Like>71 °F</Feels_Like><Temperature_Average>71.8 °F</Temperature_Average><Humidity>92 %</Humidity><Pressure>29.96 inHg</Pressure><Dew_Point>69 °F</Dew_Point><Wind_Speed>0 mph</Wind_Speed><Wind_Direction>S</Wind_Direction><Gust_Speed>0 mph</Gust_Speed><Total_Rain_Today>0 inches</Total_Rain_Today><Light>0 %</Light><Evapotranspiration>0 inches/day</Evapotranspiration><Irrigation_Requirement>0 inches</Irrigation_Requirement><Water_Deficit_Yesterday>0 inches</Water_Deficit_Yesterday><Elevation>390 </Elevation><Coverage>0</Coverage><Intensity>0</Intensity><Weather_Condition>0</Weather_Condition><Cloud_Condition>5</Cloud_Condition><Average_Temperature_Tomorrow>72 °F</Average_Temperature_Tomorrow><High_Temperature_Tomorrow>78 °F</High_Temperature_Tomorrow><Low_Temperature_Tomorrow>65 °F</Low_Temperature_Tomorrow><Humidity_Tomorrow>61 %</Humidity_Tomorrow><Wind_Speed_Tomorrow>8 mph</Wind_Speed_Tomorrow><Gust_Speed_Tomorrow>15 mph</Gust_Speed_Tomorrow><Rain_Tomorrow>0.02 inches</Rain_Tomorrow><Snow_Tomorrow>0 inches</Snow_Tomorrow><Coverage_Tomorrow>0</Coverage_Tomorrow><Intensity_Tomorrow>0</Intensity_Tomorrow><Weather_Condition_Tomorrow>0</Weather_Condition_Tomorrow><Cloud_Condition_Tomorrow>4</Cloud_Condition_Tomorrow><Forecast_Average_Temperature>78 °F</Forecast_Average_Temperature><Forecast_High_Temperature>90 °F</Forecast_High_Temperature><Forecast_Low_Temperature>67 °F</Forecast_Low_Temperature><Forecast_Humidity>65 %</Forecast_Humidity><Forecast_Rain>0.18 inches</Forecast_Rain><Forecast_Snow>0 inches</Forecast_Snow><Forecast_Coverage>14</Forecast_Coverage><Forecast_Intensity>0</Forecast_Intensity><Forecast_Weather_Condition>21</Forecast_Weather_Condition><Forecast_Cloud_Condition>3</Forecast_Cloud_Condition></climate> (climate)
2019-09-04 06:50:53 - Web Request: /
2019-09-04 06:50:54 - Web Request: /favicon.ico
2019-09-04 06:50:54 - Invalid Web Request: /favicon.ico
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLIMD added to queue (Val: 3, QS: 1)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLIHCS added to queue (Val: 0, QS: 2)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLIFS added to queue (Val: 0, QS: 3)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLIFRS added to queue (Val: 0, QS: 4)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLISMD added to queue (Val: 1, QS: 5)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV3 added to queue (Val: 0, QS: 6)
2019-09-04 06:50:54 - ISY Send: Variable ven1-ST added to queue (Val: 77.0, QS: 7)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLISPC added to queue (Val: 76.0, QS: 8)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLISPH added to queue (Val: 70.0, QS: 9)
2019-09-04 06:50:54 - ISY Send: Variable ven1-CLIHUM added to queue (Val: 70, QS: 10)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLIMD/3/67)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV2 added to queue (Val: -1, QS: 10)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV6 added to queue (Val: 0, QS: 11)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV1 added to queue (Val: 0, QS: 12)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV7 added to queue (Val: 0, QS: 13)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV5 added to queue (Val: 99, QS: 14)
2019-09-04 06:50:54 - ISY Send: Variable ven1-GV4 added to queue (Val: 0, QS: 15)
2019-09-04 06:50:54 - ISY Send: Variable ven1_s00-ST added to queue (Val: 77.0, QS: 16)
2019-09-04 06:50:54 - ISY Send: Variable ven1_s00-GV1 added to queue (Val: , QS: 17)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLIMD added to queue (Val: 3, QS: 18)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLIHCS added to queue (Val: 0, QS: 19)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLIHCS/0/25)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLIFS added to queue (Val: 0, QS: 19)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLIFRS added to queue (Val: 0, QS: 20)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLISMD added to queue (Val: 1, QS: 21)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV3 added to queue (Val: 0, QS: 22)
2019-09-04 06:50:54 - ISY Send: Variable ven2-ST added to queue (Val: 79.0, QS: 23)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLISPC added to queue (Val: 78.0, QS: 24)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLISPH added to queue (Val: 68.0, QS: 25)
2019-09-04 06:50:54 - ISY Send: Variable ven2-CLIHUM added to queue (Val: , QS: 26)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV2 added to queue (Val: -1, QS: 27)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV6 added to queue (Val: 0, QS: 28)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLIFS/0/68)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV1 added to queue (Val: , QS: 28)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV7 added to queue (Val: , QS: 29)
2019-09-04 06:50:54 - ISY Send: Variable ven2-GV5 added to queue (Val: , QS: 30)
2019-09-04 06:50:54 - ISY Send: Variable ven2_s00-ST added to queue (Val: 0.0, QS: 31)
2019-09-04 06:50:54 - ISY Send: Variable ven2_s00-GV1 added to queue (Val: , QS: 32)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLIFRS/0/80)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLISMD/1/25)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV3/0/25)
2019-09-04 06:50:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/ST/77.0/14)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLISPC/76.0/14)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLISPH/70.0/14)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/CLIHUM/70/51)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV2/-1/25)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV6/0/25)
2019-09-04 06:50:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV1/0/51)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV7/0/25)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV5/99/51)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1/report/status/GV4/0/25)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1_s00/report/status/ST/77.0/14)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven1_s00/report/status/GV1//25)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLIMD/3/67)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLIHCS/0/25)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLIFS/0/68)
2019-09-04 06:50:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLIFRS/0/80)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLISMD/1/25)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV3/0/25)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/ST/79.0/14)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLISPC/78.0/14)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLISPH/68.0/14)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/CLIHUM//51)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV2/-1/25)
2019-09-04 06:50:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV6/0/25)
2019-09-04 06:50:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV1//51)
2019-09-04 06:50:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV7//25)
2019-09-04 06:50:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2/report/status/GV5//51)
2019-09-04 06:50:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2_s00/report/status/ST/0.0/14)
2019-09-04 06:50:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/4/nodes/n004_ven2_s00/report/status/GV1//25)
2019-09-04 06:51:06 - Web Request: /index.htm
Likely means no node definition files are installed.
What happens when you try to install them from NodeLink's Devices page?
#io_guy: when I install the node definition file and reboot the ISY, it conducts the discovery process (pop-up progress bar). Once this is done, and I reboot the ISY again, there is no change to the Venstar nodes in ISY.... they still show up as lights.
No need to reboot the ISY, no idea what the discovery process is.  The node def install should be installed from the Devices Page in NodeLink.
This line tells me you haven't installed them:
Sorry- I am calling the discovery process what happens after I "Install Node Def File" and open the ISY interface. It says "Do not power off ISY or making changes while linking devices" and has a  task bar that marches from 0% - 100%.
I've tried using the "Install Node Def Files" several times without success. I've noticed that warning and it doesn't go away, even after several iterations.
I am stuck!
What's the log say when you try to install them?
Sounds like an ISY issue - you may need to get UDI involved.
Opened a support ticket with UDI. Hopefully they can figure this out.
Appreciate your work with Nodelink!
Let me know what you log looks like when you try the node install.  It might help give a hint.
  • 3 weeks later...
I'm not sure why it works now, but I moved the Nodelink from a docker instance to a Raspberry Pi and it is now working.
