Scene Update
JacquesB
Hi,
Here is another suggestion for the ISY's GUI : I would like to create scene without delays and once done, update the controller. A "Scene Update" feature, just like for the program.
It is possible to update a program, modify this, switch tab, be back and complete the update before saving it. I would like to have the same option for scene : remove this, add that, switch this from a responder to a controller, etc.
Once done, the user save the new scene and only then the new settings are pushed in the devices. I do not care if the GUI need to send 3 commands in the background for that. That's the job of a GUI : to make the manipulation easy and then translate that in computer-usable language.
Mostly, the re-programming of scenes including a RemoteLinc would be much easier, doing all the updates in one intervention.
As the GUI is right now, you can add more than one device at a time, but can not add one while removing another or switch one from a responder to a controller. It is also impossible to update 2 different scenes before sending the commands on the Insteon network. I think the GUI should handle all of that transparently.
In waiting of my next ideas for you...
Jacques
