I created a docker for this thanks as always @io_guy for the breadcrumb trails. If you don't already know docker this is probably not for you.
My full set of tags is as follows:
scyto/nodelink:latest - dotNet 3.0.0 Core and nodelinkv10.x (linux/amd64 & arm32v7 & arm64 and windows/amd64)
Linux Version
For linux  use the following command to run the container - replace $pwd% with path to your host mapped files as required (where nodelink will store its config)..
docker run --name=NodeLink -v $PWD$:/NodeLink -p 8090:8090 scyto/nodelink
Windows Version
For windows use the following command to run the container -replace $pwd% with path to your host mapped files as required
docker run --name=NodeLink -v $PWD$:C:\NodeLink -p 8090:8090 scyto/nodelink:latest
Let me know if you find issues. You can bug them on the dev github branch. Dockerhub page here https://github.com/scyto/NodeLink/tree/Dev
Edited by Scyto
now v10 is released updated to use my master branch build not dev-latest
@io_guy
Not sure if it supposed to be there?
I saw it when it was set to the default of profile 1?
I installed ISY portal on 1 (thats what it chose after i had removed all my nodes for everything)
what happened to the button in the install doc (see below and compare with mine above)?  Did it intentionally dissapear?  It was there one moment today and not the next...
FWIW: The daily program update check is returning a '404' this morning.
2019-10-26 07:41:00 - Auto-Update: Error updating file: The remote server returned an error: (404) Not Found.
  • 4 weeks later...
I just tried updating Nodelink... just saw that things were looking weird in ISY. (Venstar and GEM showing names of items as [NLS-10:ST-GV2-NAME]). Tried the install code script in the first post... not working. When I try to wget http://automationshack/Files/install-core.sh, I get a 404 error.
Running on Debian in Virtual machine on Windows 10 Pro.
Version I am currently running is 0.9.36, would like to update to latest, but unsure how.
On 9/29/2019 at 2:46 PM, Bumbershoot said:
Just an FYI:  Interestingly, the config file in '/home/pi/node' was created with 'root' ownership/permissions.  My usual practice is to keep things in user directories owned by that user, so I changed the ownership of '/home/pi/node/config.xlm' to user 'pi' to give my '/bin/systemctl' control file ('/etc/systemd/system/nodelink.service') permission to run.  I could have also just eliminated the 'User=pi' line.
[UNIT]
Description=NodeLink Server
Documentation=http://automationshack.com/nodelink.html
Requires=network-online.target
After=network-online.target
[Service]
Type=simple
ExecStartPre=/bin/sleep 10
ExecStart=/home/pi/dotnet/dotnet /home/pi/node/NodeLink.dll
Restart=always
User=pi
[Install]
WantedBy=multi-user.target
I modified my script, exactly as indicated above, but I get errors when starting it.
pi@polyglot:~$ sudo systemctl status nodelink.service
● nodelink.service
   Loaded: loaded (/etc/systemd/system/nodelink.service; enabled; vendor preset: enabled)
   Active: activating (start-pre) since Fri 2019-11-22 09:08:31 PST; 3s ago
  Process: 2192 ExecStart=/home/pi/dotnet/dotnet /home/pi/node/NodeLink.exe (code=exited, status=203/EXEC)
 Main PID: 2192 (code=exited, status=203/EXEC); Control PID: 2197 (sleep)
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/nodelink.service
           └─control
             └─2197 /bin/sleep 10
Here is my nodelink.service file:
### BEGIN INIT INFO
# Provides:             nodelink.service
# Required-Start:       $all
# Required-Stop:
# Default-Start:        2 3 4 5
# Default-Stop:
# Short-Description:    NodeLink Server
### END INIT INFO
[UNIT]
Documenation=http://automationshack.com/nodelink.html
[Service]
Type=simple
ExecReload=/bin/sleep 5 | /home/pi/dotnet/dotnet /home/pi/node/NodeLink.exe
Restart=always
User=pi
[Install]
I have tried running the install.sh, but it does have issues at the rc.local part (startup script) as I am following Bumbershoot's startup script. I am missing something really simple... question is what?
● nodelink.service
           └─control
### BEGIN INIT INFO
# Required-Stop:
# Default-Stop:
### END INIT INFO
[UNIT]
[Service]
Type=simple
Restart=always
User=pi
[Install]
Sorry, I'm traveling so I can't look at the script on my RPi, but I notice right away that you're calling 'nodelink.exe' instead of 'nodelink.dll'. You might edit 'nodelink.service' to see if that matters.  I really haven't touched Windows machines much in over a decade, so my expertise with Windows executables is low.
I will appreciate getting it when you are back. (BTW, traveling for Thanksgiving?)
I’ll be back next week, prior to turkey day.  I’ll look at my service file and repost it.  I bounced NodeLink just before I left, and it started successfully and continues to run (I get several notifications daily that report changing values in NodeLink nodes).
BTW, my experience with NodeLink on an RPi has been exceptional, both with Mono and now with DotNet.  I’m expecting the same when I install it on my Polisy.  No crashes, no nonsense.
It's no longer install-core it's http://automationshack/Files/install.sh
I doubt the script will work as it's meant for a Raspberry Pi.  It will install the wrong .NET Runtime (built for ARM)
To use Debian download:
http://automationshack/Files/NodeLink.dll
http://automationshack/Files/NodeLink.runtimeconfig.json
For the core runtime follow this:
https://dotnet.microsoft.com/download/linux-package-manager/runtime-3.0.0
or download the binary:
https://download.visualstudio.microsoft.com/download/pr/a5ff9cbb-d558-49d1-9fd2-410cb1c8b095/a940644f4133b81446cb3733a620983a/dotnet-runtime-3.0.0-linux-x64.tar.gz
So I did the following:
wget -qO- https://packages.microsoft.com/keys/microsoft.asc | gpg --dearmor > microsoft.asc.gpg
sudo mv microsoft.asc.gpg /etc/apt/trusted.gpg.d/
wget -q https://packages.microsoft.com/config/debian/9/prod.list
sudo mv prod.list /etc/apt/sources.list.d/microsoft-prod.list
sudo chown root:root /etc/apt/trusted.gpg.d/microsoft.asc.gpg
sudo chown root:root /etc/apt/sources.list.d/microsoft-prod.list
Then:
sudo apt-get update
sudo apt-get install apt-transport-https
sudo apt-get update
sudo apt-get install aspnetcore-runtime-3.0=3.0.0-1
This was found at:
Quote
When I try to run from the node folder
dotnet NodeLink.dll
I get the following:
pi@polyglot:~/node$ dotnet NodeLink.dll
Failed to load ▒▒t, error: /usr/share/dotnet/host/fxr/5.0.0-alpha.1.19564.1/libhostfxr.so: cannot open shared object file: No such file or directory
The library libhostfxr.so was found, but loading it from /usr/share/dotnet/host/fxr/5.0.0-alpha.1.19564.1/libhostfxr.so failed
  - Installing .NET Core prerequisites might help resolve this problem.
     https://go.microsoft.com/fwlink/?linkid=2063370
The link sends me to a 404 error page on Microsoft's website.
Google search led me to adding this command:
sudo apt-get install dotnet-sdk-3.0
But I still get the same above error. Any ideas?
So I just installed a fresh Debian in a VM on Windows.  Did the install as above (except I installed netcore-runtime-3.0=3.0.0-1, not netcore-runtime-3.0=3.0.0-1).
NodeLink started up without issue.
Ummm.... you typed the same thing.
Just want to make sure I type the correct stuff.
And by 'install as above' are you referencing to what I typed or something else. (Sorry to be a pain.
I did netcore-runtime-3.0 instead of aspnetcore-runtime-3.0
I have no idea what VM RPi debian is but it's most likely the issue.  Pi is ARM, Windows is x64, a VM cannot emulate a different architecture.  Mono didn't care about arch, but Net Core does.
So I managed to get 0.10.5 loaded on a Debian 9 (RPi) VM. Here is how I did it!
Fresh install from 019-04-11-rpd-x86-stretch.iso
Set my IP address to a fixed address
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install libicu57
sudo apt-get install libssl1.0.2
sudo apt-get update
sudo apt-get update
sudo apt-get install libunwind8 gettext curl wget
sudo curl -sSL http://automationshack.com/Files/install.sh | bash
I can now run the command:
However my attempts at following Bumbershoot's systemd startup script fail miserably. The /etc/systemd/system/nodelink.service file looks like this:
### BEGIN INIT INFO
# Required-Stop:
# Default-Stop:
### END INIT INFO
[UNIT]
[Service]
Type=simple
ExecReload=/bin/sleep 5 | /home/pi/dotnet/dotnet /home/pi/node/NodeLink.dll
Restart=always
User=pi
[Install]
WantedBy=multi-user.targetNode
Whenever I run status on this service I get this error message:
pi@raspberry:~ $ sudo systemctl status nodelink.service
● nodelink.service
   Loaded: loaded (/etc/systemd/system/nodelink.service; disabled; vendor preset: enabled)
   Active: activating (start-pre) since Sun 2019-11-24 20:00:38 PST; 4s ago
  Process: 5599 ExecStart=/home/pi/dotnet/dotnet /home/pi/node/NodeLink.dll (code=exited, status=255)
 Main PID: 5599 (code=exited, status=255); Control PID: 5604 (sleep)
           └─control
             └─5604 /bin/sleep 10
Nov 24 20:00:38 raspberry systemd[1]: nodelink.service: Service hold-off time over, scheduling restart.
Nov 24 20:00:38 raspberry systemd[1]: Stopped nodelink.service.
Nov 24 20:00:38 raspberry systemd[1]: Starting nodelink.service...
Also at times I see this in the status:
Nov 24 19:59:56 raspberry systemd[1]: [/etc/systemd/system/nodelink.service:10] Unknown section 'UNIT'. Ignoring.
Something I am still experiencing however is naming conventions in ISY. (What caused me to look into all of this upgrade stuff...)
All NodeLink nodes follow this naming convention for their various properties:
(box 1) - Occupied
(box 2) - [NLS-10:ST-GV1-NAME]
(box 3) - [NLS-10:ST-GV2-NAME]
....etc....
Edited by ralbright
No idea why you'd install a Pi image on Windows instead of just standard Debian.  Can't help with the service startup, I use rc.local.
I need the actual NodeLink log to work on your NLS issue.
The "server" is running Windows 10, which I have in my home, it has VirtualBox running a few VMs, one of which is Debian with the RPi load. Does that help? (It is mainly because I already have it running 24/7 in my home, why put a Pi in place when I already have it.
As for the NLS issue, I have the NodeLink running debug now. And then I go and check on my ISY again.... and it is showing the names properly. What a wonderful annoying (apparently not) issue now. ;)
logfile_2019-11-25.txt
I think "UNIT" should be "Unit".  It's case sensitive in most *nixes
I mean why would you use a RPi image instead of just plain Debian VM.  Or just run it on the Windows box straight.
Good question.... to which my answer is.... I don't know. :)
Can I ask... what is " Debian with the RPi load" ???  Raspbian is just debian for arm with some additional edu packages and hardware specific packages for rPi.
      37.6k
      376.2k
