What are the plans for the ISY (Repost of laymanspc)
Happy it works, sadly it still falls short of the support needed for most.  Most users are not going to want to alter parameters (especially if parameters are different based on version).
Thanks for the time and effort.
That's zwave in general. Gotta get on mfg. in how they set programming
As mentioned above - this is the decision of the device vendor - not the hub vendor.
If you are concerned about users altering parameters - it sounds to me as if you should consider not using zwave - as this is a common issue with this standard. Each vendor does their own thing - and sometimes changes between versions. You really need to keep a cache of documentation for devices you have. If you were to stick with Insteon you'd only have Smarthomes drifting standards to contend with...
