Polisy ship date?
32 minutes ago, MWareman said:
on Policy slot 2 shows "Solaredge" as unmanaged.
That's interesting... same slot on my Polisy ... slot 2
@mwareman
I think PolISY is the box and Polyglot and ISY will be the two coresident pieces of software making the reset terminology correct.
If you reset PolISY both software should be power cycled IMHO.
Sent using Tapatalk
@MWareman,
Thanks so very much for the update and feedback:
1. Polyglot username is not the same as the OS username. We are hoping that no one has to get to the OS/SSH (except for the geeks)
2. Letsencrypt definitely in our plan
3. Setting hostname is part of the UI (for which we held up the release)
4. Not being to upgrade poly should be resolved soon. We ran into some permission elevation issues (polyglot use does not have permission for many things and we don't want to use root). And update should be available this week and you can update Polyglot using the command:
sudo pkg update polyglot
5. Reboot will be done from the UI and will not require sudo. But, from the shell, you need sudo simply because, otherwise, we will lose audit trails
6. Getting SolarEdge is unexplainable. Please do be kind enough to send your UUID to support@universal-devices.com
