Outdoor Sensor
Hello All,
Looking for opinions from the public.
What I Need
- Outdoor motion sensor, or some sort of Car sensor to turn exterior driveway lights when cars come in.
- Sensor should be able to live through all four seasons, including winter in Northern Vermont.
What I got
- About 5 lamp posts going down the driveway. Each lampost has an outlet which is always powered on, even when the lights are off.  Constant year round power is not a problem
- Lamp Post lights are on an insteon controller and ISY can turn them on just find
- Many Insteon Devices, so I have quite the mesh already.
- The Driveway is about 150 feet long.
- Wifi is available to the road (Lot's of AP's around too :) )
- I do have the ISY994iZW+/IR-PRO. Running the latest firmware (5.0.16)
Options?
I have not found an outdoors sensor that would work. Most sensors are based on delta temperature of area, but i am not sure how well that will work when it is -20F. I have found some non-traditional, plant a magnetic detector in the ground with a home-base unit. Of course these units do not have an output, but i thought about maybe modifying it to cut the speaker wire redirect the sound to a IOLinc as an open/close relay. It might work.
Any thoughts? I cannot be the only person in the world wanting outdoor sensors.
Thanks. I passed that one many times and kept missing the fact that it included relays! Exactly what i have been looking for.
