Posted October 20, 200717 yr I am guessing this is the big discussion fix for color labeling of Local applied settings. I don't see it in any of my scenes so where should we be seeing this?
October 21, 200717 yr It should be visible within any scene when any one of the scene controllers is a responder. Select the controller from within the scene. A SwitchLinc included in a scene is the best example, though a KPL could also be the same. The difference is that a KPL can be reset remotely while most other devices have to be reset manually (remove and wait and then restore power) to make the Local Settings affective. Rand
October 21, 200717 yr Rand, Precisely. Thank you so very much. Mark, Yes, this is the compromise between color coding everything vs. those that are only controllers in a scene. With kind regards, Michel It should be visible within any scene when any one of the scene controllers is a responder. Select the controller from within the scene. A SwitchLinc included in a scene is the best example, though a KPL could also be the same. The difference is that a KPL can be reset remotely while most other devices have to be reset manually (remove and wait and then restore power) to make the Local Settings affective. Rand
October 21, 200717 yr Author Ok I found some. I was wondering...and hoping that I am not being picky...could the [applied locally] be on the end of the name instead of the begining?
October 22, 200717 yr Mark, You are being picky! Nonetheless, I don't see any harm moving it to the end. Consider it done. Thanks so very much. With kind regards, Michel Ok I found some. I was wondering...and hoping that I am not being picky...could the [applied locally] be on the end of the name instead of the begining?
