Insteon Devices
Any info helps
I have my whole home completed with Insteon dimmer switches
I had them all linked to the Insteon hub and then bought a ISY
I moved all my devices moved to the ISY and then I removed the devices from the Insteon HUB and removed it from my network.
the problem I am seeing it all my lights work fine and turn on and off outside the ISY software
what I am seeing is example
dinning room light are 2 switches, I walk up to the switches and turn them on they come on if I turn them off they turn off
if I turn them on from the ISY software they will not turn on
I look at each device and it dose show applied locally
is this my issue
if I go to the  individual devices (controller) ti turn on
responder will not turn on or off
If I go the the scene the scene will not turn on or off
I may just do a rest of both device ,remove them from ISY and start over
Controlling an individual device will only control that device not others attached to it. You just control the scene for all devices to work.
I suspect you've configured your devices in the controller but did not configure the scene too
Edited by lilyoyo1
