Looking for a wireless temp sensor for a fridge
ghaynes27
Our fridge died on us and we lost all of our food. I want to avoid having this happen again. What's the best temp sensor that will work on the ISY so I can program it to text me if the temp ever goes up again? My ISY supports z-wave but I'm having a hard time finding something that will work easily. Would like to find something thats $50 or less to handle this.
CAO Wireless Tags.
Many options to get data into ISY. Alexa direct interrogable with vocal responses, and many ways to push announcements to different devices.
Sent using Tapatalk
Zwave multi sensor 6 is very reliable.  Might be more than $50 but can be had for cheaper if you shop around.
I use two of these for both my freezers.  One freezer I shut off during peak usage and monitor temps.  The other is just for temperature monitoring.
Here is my fridge half a continent away.
I get notifications of light on too long and temperature, without my ISY.
Sent using Tapatalk
On 12/11/2019 at 11:42 AM, larryllix said:
CAO Wireless Tags.
Please elaborate on the options for integration. I see a Polyglot Node Server in the Node Server Store.  Might that be a good option?
Just ordered the hub and some sensors.  They look excellent.
Have a look in the Wireless Sensor forum for ideas.  I've used three methods to integrate tag data into my ISY: URL Calling, Kumoapps and finally the Polyglot nodeserver to manage my sensors.  All three ways work; you just need to determine which way best suits your needs and skillset.  For my 2¢, the Polyglot nodeserver offers the most utility, as the tag data is fully native and available to ISY programs.
I had a feeling this would be the case.  Will review their form but probably get lazy and just go the nodeserver route!
I use the built in kumoapp with custom code, published in another thread. Nodeserver is a good option if you have polyglot.
The tag server also has another few methods of sending analogues as well as notifications including having your cell phone app to to you.
Sent using Tapatalk
Look at all the data the nodeserver provides.  This tag is in my garage in a metal freezer, probably 75 feet from the wireless controller, with no line of sight (the usual walls, doors, etc.) between the freezer and the controller.  These things are awesome.
I agree that CAO is likely your best bet. It can notify you via text if something is wrong. ISY integration can be had but from what you describe, the tag and a tag controller will let you not only be notified when your pre set alarm points are exceeded, but can also enable you to log in via the web and check temps anytime as well. Word of advice, CAO now makes a mini zip lock bag for their tag for moisture protection. Like in a fridge. They cost like 10 cents. Make sure you add one for your tag if you go that route.
Edited by glacier991
      378.3k
