Configuration Printout
Not so much a "new" user, but an ancient one, and all that baggage that goes with aging, like forgetting a LOT of things.
Playing with my configuration today  I messed  up some links.  It dawns on me that it would be helpful for me to have a printout of my complete setup, with device/scene names, X10/Insteon addresses, etc.  Is there a ISY solution for that, or another way to export that data such that I could parse and print it?
Thanks for any suggestions.
JLOB
The handiest way I know if is to use the topology report from the Tools menu: "Tools | Generate Topology".  Save the report then use it as you see fit.
The generate topology works. I would recommend making a backup prior to making any changes. That way you can always revert should something go wrong
Thanks to both of you.  Never had a need for that, and didn't know what it was.  I do now.  Gracías.
JLOB
