Another SWL with issues
andrew77
Hi guys,
Just had a power failure and it seems I have another SWL down.
When the power came back the light didn't.
I air gapped it and it seemed to work on its own but not with the ISY.
I restored it from the ISY and I thought it was working but no.
I air gapped again and here's where things get weird. (this has happened to me before)
After pushing in the air gap tab (not pushing it in fully and then releasing, just letting it click back in)
it started going from dimmest to bright, over and over again.
I pushed the tab in and waited a few seconds.
It then started the same cycling but much faster.
(If needed I have a video of the weirdness)
its a Switch Linc Dimmer 2476D V.27
Any ideas as to what this is all about would be great.
To factory reset a switchlinc the tab button must be pressed and held until all beeps stop....without any time in the on position.
I have to use a small screwdriver or I can't do this correctly as it sounds like you did also.
There needs to be a very small time between on and pressed in and held.
Sent using Tapatalk
49 minutes ago, andrew77 said:
Hi Larry,
I don't think this SWL beeps. I thinks its older than that. Does that matter?
Drew
ewwwww. I would think they beeped as that is the only way to tell if the button pushes actually worked for a few functions. Mine does a bunch of beeping and then a very long one. When that finally stops, and not before, the switchlinc is finally factory reset.
Perhaps some of the more senior Insteon guys can chime in here. My devices are all less than about 5 years old versions.
2476d v27 is pretty old by my recollection.  You don't hold the tab in nearly as long as the new ones and it doesn't do the beeping thing.  I know this because I didn't read the instructions on the new ones and couldn't understand why they weren't factory resetting when I did it the old way.  I had a number of the old 2476d's do things like yours after power failures and I was pretty much always able to get them back online.  I would pull the tab and let it sit for a good 20 seconds then using a small screwdriver cleanly push the tab in and all the way down in one motion holding it there for a good 10 seconds.
But, I would suggest instead that you buy new 2477d with dual band.  They are much better in lots of ways including durability.  I have never had one fail.  You missed your big chance at Christmas, they were $20/ea with free shipping.  But if you are patient, I'm sure they will do that again.
Larry,
I pulled the tab out and counted forever :)
then pushed it fully in with no delay in between and held it for again, the aforementioned amount of time.
Just setting it up now. Hopefully it works.
apostolakisl,
Your response popped in as I was typing.
I had already ordered 3 on sale but where did you find them for $20 each?
I've never seen them that cheap.
UPDATE:
So the load on this SWL has been flickering bright and dim for a little while now. I assumed it was because of power surges out here.
I'm now guessing the SWL is on its way out.
Its 70% reliable as far as testing goes here tonight. I'll replace it with a new one and see how that goes tomorrow.
I'll admit to the drawer of broken Insteon switches sadly.
Can I hook them up to a three prong plug with Romex and reset/ try to see if I can get them to work?
I don't see why not as I think the old old KPLs used to have a wired cradle you could just plug in.
Drew
From Canada you need to order large quantities to make it pay. SH changes $40-$60 shipping and you wouldn't have a warranty as the return shipping is more than the device it worth.
I use aartech.ca, as they typically end up being cheaper, no matter how cheap SH sells them for.
https://www.aartech.ca/2477d-5pk/smarthome-insteon-switchlinc-dimmer-5-pack-promo.html
Sale ends Dec 31
That’s where I stocked up a few days ago. Should get them tomorrow. I think I got the 3 for $130 or something close to that.
Didn't think to see that you were in Canada.  That is pretty pathetic that you have to pay out the nose like that.  How is shipping so high?  I assume this must have to do with taxes.
The taxes, if all above board, are extra from that.
SH is typical and charges about $48 to ship and we pay taxes on that too.
I see the taxes happening inside the US also but a few decades behind. You have external affairs to pay for yet. :)
However your shipping rates are unheard of in Canada.
Sent using Tapatalk
Sent using Tapatalk
$48 shipping for a 1 pound box could not possibly go toward the shippers bottom line.  Even at retail prices USPS will ship a 1 pound box for like $8 anywhere in the US.  There must be a lot of hidden taxes or costly regulations built into that price.
      37.5k
      375k
