AT&T to end email-to-text ×
Display Annunciator
I am using 3 window sensors for my garage doors which work fine.   What I would like is a simple indicator Annunciator that would provide me visual notification if my doors are left open.
I could use a 6 button keypad for the display but it seems a waste.  I am using an ISY conroller so I can leverage Zwave devices etc.  Does anyone know of a way (other than using the ISY device status portal) as a visual display of device status?  I can think of many complicated ways of doing this such as using IFTTT, but it all seems overkill.
Any ideas?
TIA
Greg
Any ideas?
TIA
Greg
I flash a corner lamp with red flashes if either foor is open. If the gathering lights get turned off and the bedroom detects motion that lamp flashes 100% level instead of the usual 12 or 60 percent on level.
Sent using Tapatalk
I use a button on my kpls for status. If any for is open then it'll light up. For the most part mind will close automatically but hitting the button will also close whatever door is open
I just purchased inovelli no-neutral dimmers and can change the LED color based on doors locked or unlocked.
https://inovelli.com/
Also have an audible with Alexa to announce when the doors are all locked.
To do this I have several programs that set integers based on condition then change the parameters for the LEDs.  Works pretty quickly.
Program 1 - sets R_Color, G_Color and B_Color as integers based on condition. (Red for unlocked, Blue for locked (or normal))
Program 2 - is called from Program 1 to write the parameter changes.
