Do I have, again, a broken PLM ??
Hi
My ISY is accessed via Home Assistant to only control devices. All was working fine for many months until  this morning.
I initially thought I had an issue with Home assistant, so I fire up the  administrative console, but no luck. ISY cannot talk to any of my devices. I reset the PLM and reprogram it, still the same issue.
My PLM is only 1.5 years old, was already replaced twice in the last 7 years. I thought by having a 2.4 version would  free me of those problem, for at least 3-4 years, but seem not.
Before going forward, I would like to be sure I have a bad PLM, I include below a log output.
When I check for the PLM from Tools -> diagnostics -> PLM status, I only get connected.
The "reprogram" seem to have working fine.
Nothing change on the electrical side.
At this point I'm clueless on what I should do next to confirm a bad PLM, which do have a green led "on". Any advise
Regards
5603 L1 / L1_portique_banquette  Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:08:
5604 L1 / L1_portique_banquette          Mon 2020/01/13 23:08:37 System  -2
5605 L1 / L1_Portique_plafond    Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:08:
5606 L1 / L1_Portique_plafond            Mon 2020/01/13 23:08:59 System  -2
5607 Exterieur / L1_Veranda  Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:09:21 S
5608 Exterieur / L1_Veranda          Mon 2020/01/13 23:09:21 System  -2
5609 L1 / L1_SDB Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:09:43 System  Log
5610 L1 / L1_SDB         Mon 2020/01/13 23:09:43 System  -2
5611 L2 / L2_3way_esc_haut   Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:10:27 S
5612 L2 / L2_3way_esc_haut           Mon 2020/01/13 23:10:27 System  -2
5613 L2 / L2_maitre_multi.1  Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:10:49 S
5614 L2 / L2_maitre_multi.1          Mon 2020/01/13 23:10:49 System  -2
5615 L2 / L2_maitre_douche   Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:11:11 S
5616 L2 / L2_maitre_douche           Mon 2020/01/13 23:11:11 System  -2
5617 Thermostat / L1_Thermostat- Main    Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/1
5618 Thermostat / L1_Thermostat- Main            Mon 2020/01/13 23:11:33 System  -2
5619 L1 / L1_foyer   Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:11:55 System  L
5620 L1 / L1_foyer           Mon 2020/01/13 23:11:55 System  -2
5621 L1 / L1_3way_esc_bas    Error   0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Mon 2020/01/13 23:12:17 S
5622 L1 / L1_3way_esc_bas            Mon 2020/01/13 23:12:17 System  -2
5623 Get NodeDef ZWave   0   Mon 2020/01/13 23:13:38 System  Log
The revision 2.4 PLM. Has the updated Serial Port Daughter Card with better serial signal protection and C7 and C13 are now a capacitor designed for switching power supplies.
You may want to try it in a different location, look for a newly added electronic device maybe causing electrical noise or absorbing the power line signals.
Well,
I was about to move my ISY/PLM to another location but test once again. All is back to normal. I change nothing, I wonder if a good night was the answer. All I could say is for 6 hours it didn't work last night and nothing really change. I did try resetting the PLM and reprogramming it as a fix maybe that was the answer, but i swear, that it didn't work after that. Sorry for this inconvenience.
As usual, thanks for the quick feedback. A good reason to use ISY
Regards
      37.6k
      376.2k
