AT&T to end email-to-text ×
8 hours ago, leffertd said:
var url = "http://<UNIFI VIDEO IP>:7080/api/2.0/snapshot/camera/<CAMERA ID>?force=true&apiKey=<API KEY>"; //url to load image from
// Get the Camera ID from the RTSP address in Unifi Video.  "rtsp://<UNIFI VIDEO IP>:7447/<CAMERA ID>eb_1" My Id's are 22 digits of lower case and numbers.
var refreshInterval = 500; //in ms
This answers my question.  You're pulling the snapshot and not the video feed.  I was wondering how you managed to convert a RTSP feed without 3rd party interaction like Blue Iris or something but you didn't.
Well... I recently “bricked” my Polisy trying to install HP as a service. I am working on bringing it back to life.  In the mean time I am running HP on a Pi4 in my home and it seems perfectly fine.
  • 4 weeks later...
Hello kewashi@
Question, when ISY hub is done being authorized it does not seem to pull scenes and variables. Is this normal? I see all devices and programs.
Thanks so much for your work on this.
-Tim
Posted an update to HousePanel today that fixes a bunch of bugs and handles Logins properly. Version 2.270
Many people were having log in issues that this update should fix. It also permits different logins on the same server with different layouts so you can now have a different panel in each room running off the same HP server install.
  • Like 1
Variables are loaded into a single tile called Variables. Scenes are not yet supported.
  • Like 1
Are you able to create multiple pages with this?
I had irules before and had the primary page much like a control 4 layout and hoping this fills the bill
I’ve been looking for an irules replacement (without cloud) and really hope this is it.
Posted (edited)
Yup - any number of pages are supported. I call them tabs and they are all loaded up front for fast switching from tab to tab.
i think you will like HP. See screen shot with multiple tabs on top.
Edited by kewashi
Add photo
  • Like 1
  • 1 month later...
Hello Kewashi,
     I'm trying to install your HP, but when I try to use your link to add the Node.js, I receive the error below.
Connecting to node-arm.herokuapp.com (node-arm.herokuapp.com)|35.153.122.21|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2020-07-03 13:01:52 ERROR 404: Not Found.
Robert
Hi Robert - I'm not sure what the quoted statement means.  To install HP, clone the GitHub or download the zip files and unzip them into a folder on a Raspberry Pi or onto your Polisy Box if you have it set up to do so via ssh. The simplest way is to use git clone from a rPI or Polisy as follows:
git clone https://github.com/kewashi/hpserver.git
Then run "npm install" when logged into your server. Make sure you know the IP of your rPI or Polisy box - or wherever you did the install. You can also install it on a PC but I have found that it isn't convenient to leave your PC on all the time.  After you do that, then go back to your main PC and run the following:
http://<yourip>:3080
where <yourip> is the IP address of your server where you did the intall.
HP has nothing to do with Heroku so I'm confused why you would get that error. Full installation directions can be found at the HousePanel Doc Website
Posted (edited)
HP is not a device that aligns with the node server model. You need to install it separately by cloning the GitHub repo as noted above.
Edited by kewashi
  • Sad 1
That's a pity. I don' t want to mess with my Polisy.
  • 3 weeks later...
Thanks for your work on this kewashi! I seem to be stuck on 2.28 but I am happy with it and I don't really know if there is any advantage to the newer versions for me. I just tried the new version today and after having over half of my nodes setup it crashed and I can't pull up the web page after restarting the Pi and house panel?? I kept my old version and I am still able to run that so it's not that big of a deal for me.
I’m glad the old version is still working for you. I didn’t change much on the ISY side so you are fine with sticking with this version. Most of the improvements are tied to SmartThings updates and Hubitat bug fixes.  I would like to make it work for ISY so if you can share more about the crash I would be appreciative. I have the new Version 2.311 working with my ISY hub but I don’t have a very complex node structure. Anyway if you can share the crash dump that would help me fix any issues.
If you let me know what to send you I ca PM you the file. It gave an error in the browser when it crashed but I did not think to capture it because I thought just restarting it would bring it back. Now it seems like the server starts but the browser shows nothing out there. Some things I noticed adding nodes is a fanlinc needed to be on while adding it or it did not have the slider for the speeds. I place the light node over the fan node on my display and the only way to do this is the item that is placed on top must be added after the other.
Posted (edited)
You can place things on top by editing them last and moving them. That set the z-index to the next largest number.
you can also use the Tile Customizer to add the light to the fan tile using LINK and then style it in the editor to suit your tastes.
PM me the hpserver.log file after you see a crash.
Edited by kewashi
Added link info
Posted (edited)
Uploaded V2.312 that attempts to fix the problem reported above by @tazman - which turned out to be a JSON.parse error while attempting to read the hm_user.cfg file. Before using this version make sure you keep a backup copy of your .cfg files just in case. This version will replace a faulty .cfg file with a default setup.
EDIT - V2.313  posted that fixes a bug introduced in 2.309
Edited by kewashi
Is there a way to "update" instead of redoing everything? I have one folder with my 2.28 then I have been doing a new folder to try the newer versions and just typing that now since there is an install script is there any chance I am messing things up having different versions even though I only run one at a time with a reboot in between. Thanks for the help and I will post back if I find anything out.
To update you just need to replace the updated files. This new version updates hpserver.js housepanel.js and utils.js
then restart the server.
multiple folders can exist without any problem as long as only one is run at a single time.
  • Like 1
Thanks kewashi I got the new update working and I found to update and keep all of my devices all I need to do is copy the config file you mentioned and the skin house panel folder with all my pictures I use. I have to deal with my main floor plan file because it is now cutting part of the left and top of it off which I had problems getting it the correct size before.
  • Like 1
Here is my floor plan setup that I have on a separate tab in my panel. A feature I added some time ago allows the styling to be constrained to a given tab. I used this to set the titles of all the tiles here to the same look and feel and the backgrounds to transparent.
Something that I don't like seeing are the scroll bars on the bottom and right side! Is there an easy way a non programmer could integrate this into just using the background pic maybe as a SVG file but then there would have to be a hot key button to bring up the buttons on the bottom to edit things??? Just a thought I don't want to cause you a lot of work outside of your project kewashi.
      37.7k
      376.5k
