Some lights in Portal are labelled Thermostat
I just noticed this now.
I don't have a thermostat (one of the new ones) so I'm perplexed.
I tried to remove the device from the portal and re add it.
It automatically pops up as a thermostat.
Any help would be great.
Drew
Drew
What is the device in question? Does it come from a Nodeserver?
ISY Portal identifies a device using the hint of the device (the device category). If it is incorrectly set by the Nodeserver, it may incorrectly be identified as a thermostat.
Those hints are considered thermostats:
  • 1.12.x.x (Ecobee and other Nodeserver thermostats)
  • 4.8.x.x  (ZWave thermostats)
  • 5.x.x.x  (Insteon thermostat)
Benoit
Hi Benoit
Sorry for the delay. I little snowy here on the weekend. Spent more time on the tractor than usual.
I've been going through my Portal and noticed most devices are listed as Contact Sensor. I've changed some of them to Light but stopped to get this post up.
So far the ones marked Thermostat are two KPL A buttons.
Under Alexa Category, all devices give me a drop down menu except those two KPL buttons.
Drew
2 hours ago, andrew77 said:
Hi Benoit
Drew
Please post the result of:
/rest/nodes/<your kpl button address>
Benoit
1141474157_ScreenShot2020-01-20at1_22_47PM.thumb.png.19deddc0de8d230f39591c7f197b2e9b.png
I hope I've done this correctly
That's what I get.
That's what I get.
Looks like the address is wrong.
Try:
http://<your isy ip>/rest/nodes
This will give you all of your nodes. From there, you can locate the kpl button node and try the url with the correct address, or just cut and paste the node from /rest/nodes
Benoit
I'm not sure I understand what to do.
This is what I have.
<node flag="128">
<address>A D9 29 1</address>
<name>Big Room KPL-A-Sconces</name>
<type>1.12.44.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>A D9 29 1</pnode>
<ELK_ID>D10</ELK_ID>
<property id="ST" value="0" formatted="Off" uom="%/on/off"/>
</node>
The address above is the correct address for the KPL button
I don't know what ELK is as I only have INSTEON stuff.
Do I change the <type>?
<node flag="128">
</node>
ELK is an insteon compatible security system. My KPL shows the same thing it must be some alternate address for the ELK option. The ELK address given looks like the old "X-10" address scheme.
When I add my KPL-A button (on my 8 button KPL and my 6 button KPL) to Google Home or Alexa in the portal, it's category switches to "Light".  So yours doesn't?  I probably can't help much from here other than to tell you to reset the KPL to factory default and re-add it to your ISY.  It might not hurt to know your exact model number of your KPL also.
<node flag="128">
</node>
Please try again, it should be working fine now.
Benoit
It looks like its all fixed.
(sorry for not replying sooner)
Thank you
