M1EXP IP alarm monitoring and ISY at the same time
stevesreed
I could not find the answer via search, so hopefully someone here uses IP monitoring via the M1EXP though AlarmRelay or someone similar.
When using the M1EXP for IP alarm monitoring, does the ISY still get alarm events and be able to arm/disarm the alarm, etc.?
It seem like a silly equation, but I know you can't run ElkRP software at the same time as ISY access, so I wanted to make sure before switching to Alarm Relay.
Yes it does, as long as you don't leave ElkRP running.
Thanks. That is very good to know. I want to switch to IP monitoring, but did not want give up my ISY integration :)
Another confirmation from me. I use Alarm Relay and IP based monitoring and the ISY gets all the events as well..
Michael.
I had IP based reporting with my Elk, ISY, and Alarm relay for a while.  It all worked just great.  I ended up going back to phone because I just couldn't get my internet rollover to cellular with failure on primary to work right.  As soon as Elon gets Starlink working and I can put the antenna on my roof where no one can get to it and I feel confident in no loss of com, then I'll probably go back to IP.
