Manual press causes light to go on & then off?
Hi,
I have a switchlinc dimmer & it is part of a scene (basement 3 way) previously when I would press the 'main' button all lights in the basement would turn on (4 different lights).  Now when I press the button, 3 lights come on & the 4th turns on for 1 second, then shuts off. When I walk to the actual switch with the load & press the switchlinc dimmer, it does the same thing.
Any ideas why or what to check?  This might be v4 to v5 related.
Rich
Hi,
Rich
Look for a program doing this. If you right kick on any program icon there us a search option on the dropdown menu. You can search by the device name or many other options.
Sent using Tapatalk
39 minutes ago, RichTJ99 said:
Hi,
Rich
quick and dirty, just unplug ISY from the PLM and turn the light on.  If it still does it, then you know it is not an ISY command (program).  That leaves you with a defective switch.  Try factory resetting the switch and restore it from ISY.  If that fails, buy a new switch.
Hi - thanks i did try it with the PLM/ISY off & it still did it.  I then did a reset & it seems to be having issues reprogramming.  I am wondering if it is the PLM. I have a spare new in teh box - maybe I should swap that in?
Probably a bad switch.  PLM's have issues for sure, but this doesn't sound like a PLM problem.  Is your ISY having troubles communicating with anything else?
Since you had both isy and plm unplugged, I would say the likelihood of it being either one is zero
