Backup Failing
@Michel KohanimI am getting a zip file could not be created with another error "Could Not Retrieve File /CONF/NODES/UN0205.BIN while trying to backup.  I am running 5.0.16B and have successfully created backups previously with this version.
I see other issues that are similar in the forums but none with a .bin extension.  My question is, can I safely delete it and try again like the other similar issues?  Or do I just need to go back to a previous backup and restore?  I have several changes that I'd like to keep but if going back is the only way then I'll do that.  Thanks!
New java update recently?
Sent using Tapatalk
Not that I am aware of.  It is doing the same between the two computers I have tried from.
Edit: Jan 20 was the last java update and I have successful backups since then.
Edited by btreinders
Thanks!  That did it.  I had to delete another as well but it is backing up successfully now.
@Michel Kohanim, I am having a similar backup issue.  I am on 5.0.16B.  When I try to backup, I get 'Could Note Create the Zip File' and 'Could Not Retrieve File /CONF/NODES/4F9553.REC' errors.  I can telnet in and delete this file.  Is it safe to delete this REC file?
-Emile
