File errors logged during startup
Hi all,
When my ISY-99i starts, I'm seeing the following log entries:
0	null	 	Mon 08/31/2009 09:25:52 AM	System	Start
0	/CONF/A	 	Mon 08/31/2009 09:25:59 AM	System	-110022
0	/CONF/F	 	Mon 08/31/2009 09:25:59 AM	System	-110022
The error code appears to indicate missing or damaged files. Is this any cause for concern? If so, how to correct?
-Jim
Hi Jim,
I think they are related removed devices which were removed but the associated configuration files were not removed.
Quick questions before applying the procedure to fix:
1. Do you have any of your scene which cannot be programmed (on level/ramp rate)?
2. Do you have any of your devices which are not operating properly and/or are missing?
If the answer to both of these questions is NO, then please:
1. Telnet to your ISY
2. Login
3. Issue FN (Fix Nodes)
Hi Jim,
2. Login
Hi Michel,
Thanks for your prompt response. AFAIK, the answer to both questions is no, so I went ahead and ran the FN command. It reported that several files with the extension UND were fixed and rebooted the ISY.
However, I'm still seeing the same errors involving /CONF/A and /CONF/F in the log file.
Anything else to check? I can back up the ISY and all devices are working normally, so the only concern is that the file system inconsistency might cause trouble in the future.
-Jim
Ah, I am so very sorry!
Those are configuration files for Open Auto DR and Flex Your Power (under Electricity tab). Since you have not configured them, it's just a warning that the modules could not be initialized. So very sorry for the wrong answer!
Hi Michel,
What about /CONF/E? I see this also in my log?
Ruben
Hello Mr. Aldridge,
E is for energy ... simply add a price under the electricity tab.
Hi Michel,
Ruben
