All Lights on/off
All,
New to ISY.
How do I set up all my lights going on/off via one command?
Seems the complication is I have several 3 way switches already in a scene and not sure how to figure them in...
tnx
Jeff
Details!!!! What's all lights? Just the 3 way, whole house, only the room, is this done manually from certain locations, via a program....etc.
Oh, thanks for the reply.
Well just want to be able to either use Mobilinc to kill all lights in all rooms.  Some are 1 way and some are 3 way.  Also may want to do the same with a insteon button switch.
So don't know if I need it via a program or a scene.  Have scenes to run the 3 way lights.
Thanks for ideas...
If it's only via mobilinc, create 1 scene, add all devices to that scene and then you can turn all off.
Every room in my house has its own all on/off scene. I have a program that will activate each scene 1 at a time for functions where I'm shutting down the whole house such as my away or vacation mode
Ok, got it.  Thank you!
Any ideas on my Polisy question I listed?  :)
One question.  If I have 3 switches in a 4-way switch, do I add all 3 of them as a controller or responder to the "all scene", or just one of the 3 switches?  Assume in you answer they go in as responders.
Each switchlinc with a load should be a responder. Each switchlinc that is going to control the load(s) should be joined as a controller. Some will be both.
Make sure you factory reset every Insteon device before linking it to ISY! You will save yourself a lot of agro later.
You would have separate scenes for your 4 way switch. In the main scene for them, all would be controllers. In your whole house scene, all would be responders. The same would apply if you had a scene to control the whole room. Everything would be a responder.
What polisy question? This post only talks about scenes
Ok got it, super cool.  You guys are awesome.  Thank you for helping us newbies!
You're welcome. Send toilet paper!
