Use portal remotely to modify ISY program
I am new to ISY. When I access my ISY through the Portal remotely (https://my.isy.io/index.htm), I do not know how to access a program to modify it. Is this possible? Do I need to remotely access the admin console?
ISY uuid:00:21 :b9:02:55:99
Firmware
lnsteon_UD994_OADR v.5.0.16C ( 2020-01-25-12:36:41)
UI lnsteon_UD994 v.5.0.16( ( 2020-01-25-12:26:39)
ISY 994i/lR PRO (1110)
OpenADR (21010)
- Z-Wave (21100)
- Portal Integration -
UDI (21075)
Chrome browser
UD tech support walked me through how to access the admin console remotely using the Portal. Problem solved.
  • 3 weeks later...
It would be great if you explained how the issue was solved.
I am trying to access my Admin Console remotely and for some reason entering the https:// address of my remote ISY into the ISY Finder is not working... so I am hoping that access through the portal will work.
Did you get your isy address from the portal? If so, make sure that you're using your portal user name and password
Thank you... that is cool! I didn't know we could do that!☺️
Is there any way to edit programs via the portal? (In a browser, I mean)  Thanks!
not in browser, however these instructions allow you to run the admin console and connect via the portal.
Thanks Mr Bill. That allows remote access using the Java client, which aint nothing. But I was hoping for something without any client at all. The portal is very very close, but I cannot edit my programs.
Thanks for the info,
D
UDI has transitioning the Java client to a Web-based editor on their roadmap, but they currently have their hands full with v5 and Polisy, from what I gather
Sent from my SM-N9500 using Tapatalk
