temperature triggerd attic fan control
I'd separate this into two programs so that it can turn on at >= 90 and off at <88 or somethings.   With only a single program two things come to mind the fan would go on/off frequently.  Also I'd use and AND in If's to prevent excess traffic because each time the temp changes on or off is sent regardless of whether it's already on / off.
Here's examples I use with my fireplace:
Fireplace-cycle off - [ID 0078][Parent 007C]
        $Fireplace.down.cycle is 1
    And '#1704 / Downstairs Fireplace' Temperature >= '$Fireplace.down.setpoint Fahrenheit'
    And 'DN Fireplace#' Status is On
        Set 'DN Fireplace#' Off
Fireplace-cycle on - [ID 0079][Parent 007C]
    And '#1704 / Downstairs Fireplace' Temperature < '$Fireplace.down.setpoint.hysteresis Fahrenheit'
    And 'DN Fireplace#' Status is Off
        Set 'DN Fireplace#' On
Variable name
Purpose
cCoat_closet_fan_off_temperature
Temperature at or below which the fan turns off [F].
Set to 92.0
Invariant: cCoat_closet_fan_off_temperature < cCoat_closet_fan_on_temperature
Temperature at or above which the fan turns on [F].
Set to 93.0
Coat closet fan on when hot
        'Foyer / Coat closet multi-sensor' Temperature > '$cCoat_closet_fan_on_temperature Fahrenheit'
        $sCoat_closet_fan  = 1
Sets the state variable to the "fan on" state if the temperature
is above the upper limit.
Coat closet fan off when cool
        'Foyer / Coat closet multi-sensor' Temperature < '$cCoat_closet_fan_off_temperature Fahrenheit'
        $sCoat_closet_fan  = 0
Sets the state variable to the "fan off" state if the temperature
is below the lower limit.
Coat closet fan on/off
        $sCoat_closet_fan is 0
        Wait  10 seconds
        Set 'Foyer / Coat closet vent fan' Off
        Wait  10 seconds
        Set 'Foyer / Coat closet vent fan' On
Turns the fan in the coat closet on or off depending on the value of
the state variable. The delays make sure that the fan runs at least
a certain amount of time (debouncing).
Edited by jfai
Thanks for your feedback so quickly!
Mr. Bill - Are these 3 things Devices? or variables?
'$Fireplace.down.setpoint Fahrenheit'Is
In addition to what MrBill said, I would add a wait to the then command. I do this with my ceiling fans so that they arent triggered due to a temporary temperature change. Its not needed but its helped prevent my fans from cycling on and off for no reason.
thank you iliyoyo1
jfai,
Thanks you your advice.
Is Foyer / Coat closet multi-sensor' a device?
$Fireplace.down.cycle   = State Variable
'#1704 / Downstairs Fireplace' Temperature   =  Wireless tag Temperature Node
'$Fireplace.down.setpoint Fahrenheit'Is     =  State Variable
If you don't want to have an override switch, you could skip $Fireplace.down.cycle
There is actually 3 more programs that work with these 2 for a group of 5.
Essentially there are 2 buttons on a 8 button controller that are controllers for the scene.   'DN Fireplace#' is also a responder to the scene.
The extra "status" line in the IF of the cycle-on and cycle-off programs takes are of updating when the scene is turned on / off via alexa, or an iphone APP.  the single Status is perhaps all that's needed, except this forum taught me to use Control in If's early on.... then when Alexa came along I added the 'status' lines also.
I actually have another set of 5 programs for another fireplace.... these have worked very.   Haven't needed delays, the temps only update once per minute.
All 5:
Fireplace-Downstairs - [ID 007C][Parent 0001]
Folder Conditions for 'Fireplace-Downstairs'
Fireplace-Downstairs-off - [ID 007B][Parent 007C]
        'DN Back Door Recessed+# / {hide}Fireplace Downstairs' is switched Off
     Or 'DN Back Door Recessed+# / {hide}Fireplace Downstairs' is switched Fast Off
     Or '{hide}OUT Lower Fans - High / {hide}DN Fireplace' is switched Off
     Or '{hide}OUT Lower Fans - High / {hide}DN Fireplace' is switched Fast Off
     Or '{hide}OUT Lower Fans - High / {hide}DN Fireplace' Status is Off
     Or 'DN Back Door Recessed+# / DN All Off' is switched Off
     Or 'DN Back Door Recessed+# / DN All Off' is switched Fast Off
        $Fireplace.down.cycle  = 0
Fireplace-Downstairs-on - [ID 007A][Parent 007C]
        '{hide}OUT Lower Fans - High / {hide}DN Fireplace' is switched On
     Or 'DN Back Door Recessed+# / {hide}Fireplace Downstairs' is switched On
     Or 'DN Back Door Recessed+# / {hide}Fireplace Downstairs' Status is not Off
        $Fireplace.down.cycle  = 1
Setpoint hysteresis - [ID 00E4][Parent 007C]
        $Fireplace.down.setpoint < 80
    And $Fireplace.down.setpoint >= 60
        $Fireplace.down.setpoint.hysteresis  = $Fireplace.down.setpoint
        $Fireplace.down.setpoint.hysteresis -= 1
        $Fireplace.down.setpoint  = 73
        $Fireplace.down.setpoint.hysteresis  = 72
When the setpoint value changes, and the new value is sane, then set hysteresis value.
When the new value is NOT sane, set default values.
Edited by MrBill
