how many links?
i am curious about how many links people have (devices and scenes) - as i understand it, a scene counts as one link - a keypad in 6 button config counts as 5 links and a keypad in 8 button config is 8 links - all others count as 1 link
slooplinc's insteon
relay - 14
dimmer - 13
lamplinc - 14
icon lamplinc - 1
keypad (6 button) - 18
keypad (8 button) - 5
plm - 1 = no links
rflinc - 4 = no links
plc - 1 - in the craplinc box - no links
device links - 172
scenes - um - i forgot - but lots
anyone else pushing their luck?
Sloop,
There's indeed an ISY Startup Trap Error bug which we've fixed in version 2.2.
Thanks and with kind regards,
I do have only 119 links in the PLM, right?
I still have about 20 more links to add for my train lights and I plan on adding another ContrLinc or two, so another 20 or so links then. I might use some Insteon in the master bedroom but I don't see more than additional dozen devices being added to this home (about 30 installed now) so I doubt if I will double the number of links.
What will I have to do if I exceed 255 links? A second ISY with another PLM? Or a second PLM with one ISY?
  • 1 month later...
Rand,
Wow, I just realized that this submission of yours had remained unanswered. My sincere apologies (can't trust the auto notificiation).
In case you exceed 255 nodes (device/scene), you will have to get a our new product which handles 512. I've yet to see anyone going beyond the 210 devices (for a 12000 sq feet house) and 45 scenes.
Michel,
I am more worried about the number of links. I now count 205 links.
Every time I create a new scene I create more links, correct?
If I create a new scene with six responders I have six new links.
Am I going to run out of room in the PLM?
Thank you,
Rand
Rand,
Hello. You are correct! PLM is supposed to allow for 417 links. So, I don't think you will run out of PLM links any time soon.
Does this answer your question?
Michel,
Thank you,
Rand
Michel, Yes, my fears are alleviated. I was confused concerning the # of links in the PLM. Some of the PLM descriptions noted 256 links, others specified 417.
Thank you,
Rand
Rand,
I am glad your fears are alleviated ... unless, of course, I've been given the wrong information by SmartLabs. I've sent an email to get a confirmation and I will let you know if I am told otherwise.
Thanks so very much and with kind regards,
Thank you,
Rand
  • 2 months later...
Hey guys,
I put together a little java calculator for this question for all to try. Michel double checked my math and uploaded it over here.
ISY PLM Link Calculator
It is a close approximation tool because you can't fully know the average nodes in a scene but this will get everyone a close enough number to understand their setup.
Anyone with a Mac? Let me know if this calc does not work for some browsers because it was only tested on Microsoft Internet Exploder.
Mark
Mark,
That's a great tool. Thanks for working on it. Where would the EZIO stuff fit in?
For example, would including my EZRain as an Eight Button KPL give a reasonable approximation (there are eight relays)? Also, the EZIO8SA has 8 relays as well as 4 inputs and the EZIO2X4 has 2 inputs and 4 relays. These devices begin to add up very quickly.
George
Let me see if I can figure out the counts for the EZIO stuff and add them to the calculator. I am sure Michel would not mind an update.
The calculator shows me at 662 links and I am about to order some more stuff... should I be worried? Will the ISY-99.9 work for me?
0 8-button keypads
13 6-button keypads
10 ControLincs
5 RemoteLincs
102 Switches
48 Plugin Modules and SocketLincs
Did not count PLCs on Homeseer, PowerHome, and X-10 translator,
Did not count EZIO8 or EZX10RF
(Hope to eliminate after ISY is installed)
Will be adding more SockeLincs, ApplianceLincs, Relay switches, KeypadLinc Relays, and RemoteLincs (say 10 more devices total).
Mark,
Thank you so very much.
GPG,
I am going to work with Mark to get the numbers in there for EZRain. As far as EZIO, ISY has stopped working with any of the new firmware versions of EZIOxx especially those attached to/using PLM v.52. Unfortunately, it's quite impractical for us to support devices for which we are not notified of the changes in behavior, APIs, and ramifications between different revisions/versions. Therefore, our support for EZIOxx devices is currently as-is and unofficial. In this respect, then, I feel a little hesitant adding EZIOxx in the list.
upstatemike,
ISY can support 512 device/scene combinations. Right now, you have a maximum of 400 distinct INSTEON buttons (nodes in our vernacular). That leaves you with 112 scenes.
The current PLM (v. 52), though, will not support your number of links. You would either have to use their Beta (which supports 1600 links) or wait for its official release.
X-10 Translator does not take any links if you use ISY for triggers/actions.
How many PLCs do you have?
I still have to get back to you with respect to HomeSeer integration.
0 8-button keypads
13 6-button keypads
10 ControLincs
5 RemoteLincs
102 Switches
Mark and Michel,
Thanks for considering adding the EZRain, but I did not mean to suggest that the tool should be modified, because it certainly covers most of the popular devices. I was just looking for a category to use for a reasonable estimate of the EZRain devices. I currently have one EZRain, EZIO2X4 and EZIO8SA. If I knew that each input used 1 link and each relay used 2 links, for example, I could make the manual calculation and add it to the tool's total count for a more precise calculation.
George.
GPG,
No problem at all. For EZIO:
Each Input takes 2 links
Each Output takes 1 link
Mark and Michel,
George.
Hello Michel:
When SH finally releases the 1600 link PLM, will we be able to easily swap it into our ISY network? I know that you guys are really on top of things, so I'm assuming that your code will be updated to allow for a seemless swap-out to the new "high link" version of the PLM.
Best wishes
upstatemike,
I Have the original SmartHome X-10 translator which is a PLC
PowerHome uses a PLC
Homeseer is currently a PLC but will be switched to a PLM
EZX10RF is PLM based?
EZIO8 has a PLM
My Plan:
Install a W800RF32A on my ELK panel and connect the ELK to an ISY 99.9
This will let me eliminate both of the EZ units and the X-10 translator.
Convert Homeseer from the PLC to a PLM (Homeseer will not support the PLC in future releases. Not sure how ISY and Homeseer will work together yet.
PowerHome only supports the PLC at this point but I will likely take it off line when I bring up the ISY.
So the short answer is that I don't plan to keep any PLCs and just have to figure out how to work with Homeseer's PLM. Would be nice if Homeseer communicated to the ISY over the network like the Elk so I could have only 1 Insteon interface to manage.
upstatemike,
Good plan. I still have to get back to you with respect to HomeSeer integration. I haven't forgotten and it's on the list of my things to do in the coming days. I shall keep you posted.
upstatemike,
EZIO8 has a PLM
My Plan:
i went back and recounted my links - using these rules
remotelinc - 6 links
controllinc - 5 links
responding device - 1 link
controlling device - 2 links
keypad (6 button mode) - 5 links
keypad (8 button mode - 8 links
each member of a scene counts as 1 link (its status as controller or responder does not matter - the scene itself does not count as a scene - only the participating devices)
devices
keypads (6 button mode) - 18 - counts as 90 links
keypads (8 button mode) - 5 - counts as 40 links
relays - 14 - counts as 28 links (controlling device)
dimmers - 13 - counts as 26 links (controlling device)
lamplincs - 15 - counts as 15 links (responding device)
199 device links
scenes
45 scenes with 223 participants in these scenes
199 + 223 = 422 links
an interesting observation - my 5 keypads that operate in 8 button mode are pedestal mounted - so they have no load
422 - 5 = 417
417 is the plm link limit
sloop,
The PLM does not care about whether or not your KPL controls a load and, therefore, you still have 422 links!
devices
199 device links
scenes
422 - 5 = 417
