Hue Emulator Issues
Recently, there was an update to the Hue emulator - after installing, I have been experiencing issues where basically some of my Harmony Companion Home Automation buttons no longer work; the strange thing is that some buttons do work some of the time, but some times none work at all - anyone else experiencing problems?  If so, any thoughts on how to fix?
Here's part of a log file below - I tried to turn on a scene called Fireplace Lt Dim:
020-07-15 09:50:59,513 Thread-83021 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-15 09:50:59,514 Thread-83021 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 44260)
2020-07-15 09:50:59,516 Thread-83021 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-15 09:50:59,517 Thread-83021 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
    self.finish_request(request, client_address)
2020-07-15 09:50:59,518 Thread-83021 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
    self.RequestHandlerClass(request, client_address, self)
2020-07-15 09:50:59,518 Thread-83021 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-15 09:50:59,519 Thread-83021 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
    dst = device.set(parsedContent)
2020-07-15 09:50:59,520 Thread-83021 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
    ret = self.set_bri(data['bri'])
2020-07-15 09:50:59,521 Thread-83021 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
    LOGGER.info('{} on val={} dimmable={}'.format(self.name, value, self.node.dimmable));
2020-07-15 09:50:59,521 Thread-83021 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-15 09:50:59,522 Thread-83021 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-15 09:50:59,949 Thread-83022 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'xy': [0, 0], 'on': True, 'bri': 254}
2020-07-15 09:50:59,951 Thread-83022 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-15 09:50:59,952 Thread-83022 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-15 09:50:59,952 Thread-83022 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 44261)
2020-07-15 09:50:59,954 Thread-83022 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-15 09:50:59,956 Thread-83022 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
2020-07-15 09:50:59,956 Thread-83022 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
2020-07-15 09:50:59,957 Thread-83022 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-15 09:50:59,958 Thread-83022 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
2020-07-15 09:50:59,959 Thread-83022 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
2020-07-15 09:50:59,959 Thread-83022 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
2020-07-15 09:50:59,960 Thread-83022 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-15 09:50:59,961 Thread-83022 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-15 09:51:00,392 Thread-83023 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'xy': [0, 0], 'on': True, 'bri': 254}
2020-07-15 09:51:00,393 Thread-83023 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-15 09:51:00,394 Thread-83023 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-15 09:51:00,394 Thread-83023 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 44262)
2020-07-15 09:51:00,396 Thread-83023 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-15 09:51:00,398 Thread-83023 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
2020-07-15 09:51:00,399 Thread-83023 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
2020-07-15 09:51:00,399 Thread-83023 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-15 09:51:00,400 Thread-83023 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
2020-07-15 09:51:00,401 Thread-83023 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
2020-07-15 09:51:00,402 Thread-83023 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
2020-07-15 09:51:00,403 Thread-83023 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-15 09:51:00,403 Thread-83023 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-15 09:51:01,242 Thread-83024 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.35: Sent all lights response
2020-07-15 09:51:03,100 Thread-83025 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'on': False}
2020-07-15 09:51:03,101 Thread-83025 ISYHueEmu          INFO     ISYHueEmu:set_off: Fireplace Lt Dim node.turn_off()
2020-07-15 09:51:03,102 Thread-83025 ISYHueEmu          INFO     connection:request: ISY Request: http://192.168.2.119:80/rest/nodes/53050/cmd/DOF
2020-07-15 09:51:03,145 Thread-83025 ISYHueEmu          INFO     ISYHueEmu:set_off: Fireplace Lt Dim scene.turn_off() = True
2020-07-15 09:51:06,119 Thread-83026 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.33: Sent all lights response
2020-07-15 09:51:08,870 Thread-83027 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.34: Sent all lights response
2020-07-15 09:51:11,396 Thread-83028 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.35: Sent all lights response
Edited by jtsao
add log file
Well, after posting I did some more investigation and for some reason, a node under the Ping Nodeserver had Spoken=1 (it was an iPhone) and was showing up as a Hue Controllable device in my Harmony hub.  Not sure how that happened as I never set that property but after clearing it, now things seem to be working.
After further review, there is still a problem; for some reason everything was working right after I fixed the problem node - but after that things returned to mostly not working;
not sure why but some times some of the scenes can be turned off only and others just don't work - here is the output when trying to turn on the same scene as before
2020-07-16 21:51:23,144 Thread-50046 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'xy': [0, 0], 'on': True, 'bri': 254}
2020-07-16 21:51:23,146 Thread-50046 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:23,147 Thread-50046 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-16 21:51:23,147 Thread-50046 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 48980)
2020-07-16 21:51:23,149 Thread-50046 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-16 21:51:23,150 Thread-50046 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
2020-07-16 21:51:23,151 Thread-50046 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
2020-07-16 21:51:23,152 Thread-50046 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-16 21:51:23,153 Thread-50046 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
2020-07-16 21:51:23,154 Thread-50046 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
2020-07-16 21:51:23,154 Thread-50046 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
2020-07-16 21:51:23,155 Thread-50046 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-16 21:51:23,156 Thread-50046 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:24,036 Thread-50047 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'xy': [0, 0], 'on': True, 'bri': 254}
2020-07-16 21:51:24,037 Thread-50047 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:24,038 Thread-50047 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-16 21:51:24,039 Thread-50047 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 48981)
2020-07-16 21:51:24,041 Thread-50047 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-16 21:51:24,042 Thread-50047 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
2020-07-16 21:51:24,043 Thread-50047 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
2020-07-16 21:51:24,044 Thread-50047 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-16 21:51:24,044 Thread-50047 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
2020-07-16 21:51:24,045 Thread-50047 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
2020-07-16 21:51:24,046 Thread-50047 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
2020-07-16 21:51:24,047 Thread-50047 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-16 21:51:24,048 Thread-50047 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:24,516 Thread-50048 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Parsed Content data: {'xy': [0, 0], 'on': True, 'bri': 254}
2020-07-16 21:51:24,518 Thread-50048 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:24,518 Thread-50048 polyinterface      ERROR    polyinterface:write: Exception happened during processing of request from
2020-07-16 21:51:24,519 Thread-50048 polyinterface      ERROR    polyinterface:write: ('192.168.2.32', 48983)
2020-07-16 21:51:24,521 Thread-50048 polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2020-07-16 21:51:24,522 Thread-50048 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 650, in process_request_thread
2020-07-16 21:51:24,523 Thread-50048 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
2020-07-16 21:51:24,524 Thread-50048 polyinterface      ERROR    polyinterface:write: File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
    self.handle()
2020-07-16 21:51:24,525 Thread-50048 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 420, in handle
2020-07-16 21:51:24,526 Thread-50048 polyinterface      ERROR    polyinterface:write: File "hue-upnp/hueUpnp.py", line 541, in set
2020-07-16 21:51:24,526 Thread-50048 polyinterface      ERROR    polyinterface:write: File "/var/polyglot/nodeservers/HueEmulator/ISYHueEmu.py", line 313, in set_bri
2020-07-16 21:51:24,527 Thread-50048 polyinterface      ERROR    polyinterface:write: AttributeError: 'Group' object has no attribute 'dimmable'
2020-07-16 21:51:24,528 Thread-50048 polyinterface      ERROR    polyinterface:write: ----------------------------------------
2020-07-16 21:51:26,757 Thread-50049 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.34: Sent all lights response
2020-07-16 21:51:26,995 Thread-50050 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.33: Sent all lights response
2020-07-16 21:51:27,190 Thread-50051 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.35: Sent all lights response
2020-07-16 21:51:33,713 Thread-50052 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Sent all lights response
2020-07-16 21:51:36,918 Thread-50053 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.34: Sent all lights response
2020-07-16 21:51:37,154 Thread-50054 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.33: Sent all lights response
2020-07-16 21:51:37,361 Thread-50055 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.35: Sent all lights response
2020-07-16 21:51:43,907 Thread-50056 hueUpnp            INFO     hueUpnp:info: hueUpnp:HTTP: 192.168.2.32: Sent all lights response
I uninstalled, then re-installed but still same problems - mostly not working;  When using my phone's Harmony App to control the Harmony Hub, I can see after I try to turn a light on, I get a "No Connection" message most of the time.  Prior to recent problems, I had been using this daily for months.  The unfortunate thing is that Logitech limits the buttons on the companion remote to only work with certain vendor's devices such as a Hue or Insteon Hub, - I can't really use them to control lighting/fans with the ISY directly.
Edited by jtsao
    self.handle()
    self.handle()
    self.handle()
This is a bug for some scenes, I will try to fix it but probably won't have time for a few days.
Sent from my Pixel 3 XL using Tapatalk
No worries - I have multiple other ways to control insteon equipment (web browser, IR) thanks for all of your work on this node server
I noticed an update was available yesterday and I briefly tested it - appears to be fixed - thanks!
