Garage Door Sensor gets out of sync
I have two IOLinc's that I use to control my two garage doors. Everything works fine until I re-boot my ISY. I just did this a few days ago and when I push my garage door button the garage door go up about half way and stops. Sometimes it even goes up half way and then closes on it's on. If I unplug my IOLinc the garage door opener works fine.
When my ISY re-booted it must have made my IOLinc out of sync. The only way I could fix it is to delete my IOLinc (GarageDoor-Sensor/GarageDoor-Relay) and to re-install. It then creates entries
1. GarageDoor-Sensor
2. GarageDoor-Relay
When I do that everything works fine.
I am sure there is a better and much easier way of fixing this problem should it occur again.
Thanks as usual for all your help.
What mode do you have your Relay in? My understanding is if you have Trigger Reverse selected it will be un-selected after a power outage or reboot.
Yeah and 3:00 AM queries also show up un-reversed and cause grief.
Need to write you own code or modify the standard published code to adapt insetad of using the reverse feature.
Another option. Would get the original magnetic switch in the early Garage Door Kits. So you didn't have to use the Trigger Reverse function. I had both a NO and NC connection you could choose from.
Edited by Brian H
Thanks for the replays and help. I am not using the "Trigger Reverse" mode. I only have Momentary B and LED on TX selected.
