5.2.0 Schlage Lock issue
I posted this on the 5.1.0 thread and didn't seem to get a response, I am seeing this same issue on 5.2.0;
I have a few strange things happening with my two Schlage Z Wave locks. I am using the 500 series adapter with version 6.81.00. Both locks are now showing with the green write updates to device icon. One of them now has a sub item called Multilevel sensor which I normally only see on my Aeotec devices. They do seem to be working normally. If there is a way to fix this without having to bring the locks close to the ISY that would be great because it's a pain to move them, but will do if thats the only fix.
I have an older Schlage deadbolt that exhibits the same behavior.  It works normally, but there's no way to eliminate the update icon.  If you exclude the lock, then you won't be able to include it securely in 5.1.0 (I don't know about 5.2.0).   This post suggests that the newer Schlage deadbolts work better with the 500 series Z-Wave board.
