writing a toggle program
I am wanting to use an IR remote to toggle an insteon light switch with the press of a single button. I have to believe there is a way to do this by writing one program, but have found that I can only get it to work by writing 2.
Status "kitchen light' is off
and IR "IR_001' is pressed
then
set scene 'kitchen lihgt' on
else no action
This turns the light on
Status 'kithchen light' is not off
and IR 'IR_001' is pressed
set scene 'kitchen light' off
else no action
This turns it off
So again, the question, is there a way to merge these two programs into one program to toggle the light on/off with the press of the IR button?
Hello apostolakisl,
The functionality you desire does require two programs. There are various ways it could be done using two programs, but the way you have outlined is probably the best.
Don't be too concerned though, as the ISY can handle many programs 8) .
