Bumbershoot Posted November 21, 2020 Share Posted November 21, 2020 Okay, shortPoll set to 900 and restarted. Link to comment Share on other sites More sharing options...
bcdavis75 Posted November 21, 2020 Share Posted November 21, 2020 Mine appears to have died. Yesterday sometime. shortpoll is set to 1800. I havn't changed it since the first time I extended it. 168283343_SonosLog.htm Link to comment Share on other sites More sharing options...
simplextech Posted November 21, 2020 Author Share Posted November 21, 2020 3 hours ago, bcdavis75 said: Mine appears to have died. Yesterday sometime. shortpoll is set to 1800. I havn't changed it since the first time I extended it. 168283343_SonosLog.htm 2.01 MB · 1 download And it looks like the typical SSL error.... Hmm... Link to comment Share on other sites More sharing options...
Michel Kohanim Posted November 23, 2020 Share Posted November 23, 2020 All, all systems are running smoothly but the number of Sonos node servers has increased by 10. So, to summarize, shortening the poll did have any impact or not? With kind regards, Michel Link to comment Share on other sites More sharing options...
Bumbershoot Posted November 23, 2020 Share Posted November 23, 2020 1 hour ago, Michel Kohanim said: All, all systems are running smoothly but the number of Sonos node servers has increased by 10. So, to summarize, shortening the poll did have any impact or not? With kind regards, Michel Not conclusive, apparently. I suspect that lengthening the shortPoll value from 60 seconds to 1800 had a positive impact on the SSL errors I was getting. However, @bcdavis75 reported an SSL error with his shortPoll value set to 1800, so maybe not... I set my shortPoll value to 900 and will let it run. Link to comment Share on other sites More sharing options...
simplextech Posted November 23, 2020 Author Share Posted November 23, 2020 Thinking of the PGC architecture of the container instances in the K8 cluster I have to ask if they are all going outbound through a single K8 egress? The errors everyone gets are disconnects from upstream..... What's the statistics from the K8 cluster egress? How about AWS egress stats? Could this not be a Sonos API disconnect but more localized? Link to comment Share on other sites More sharing options...
bcdavis75 Posted November 28, 2020 Share Posted November 28, 2020 Died again yesterday. At this point, I have to conclude the polling frequency is not the problem... at least not for me. Link to comment Share on other sites More sharing options...
Bumbershoot Posted November 28, 2020 Share Posted November 28, 2020 I'm currently up for 54+ hours with a 15 minute shortPoll setting. Link to comment Share on other sites More sharing options...
bcdavis75 Posted November 28, 2020 Share Posted November 28, 2020 Interesting. Based on timing, I wonder if I expiernce errors that are common to all of us and then some that are unique to my environment? Next time mine fails and your doesn't, I'll upload the log. I wonder if there's enough detail in the error to differentiate? I'm not techinical enough to know myself. Link to comment Share on other sites More sharing options...
simplextech Posted November 29, 2020 Author Share Posted November 29, 2020 I pushed V 0.2.22 which has some more exception handling for requests and I wrapped the whole shortPoll process into a try/except to see if there's something I can gather from that output. Link to comment Share on other sites More sharing options...
bcdavis75 Posted December 2, 2020 Share Posted December 2, 2020 Well... things are in a weird state. now. A couple days ago it failed. I tried restating and it SEEMS to restarted however, the current status says 'disconnected' on the dashboard. I believe I had updated to your new version prior to this failure. sonoscontroller-0021b902512a-2 (4).txt Link to comment Share on other sites More sharing options...
simplextech Posted December 2, 2020 Author Share Posted December 2, 2020 46 minutes ago, bcdavis75 said: Well... things are in a weird state. now. A couple days ago it failed. I tried restating and it SEEMS to restarted however, the current status says 'disconnected' on the dashboard. I believe I had updated to your new version prior to this failure. sonoscontroller-0021b902512a-2 (4).txt 41.95 kB · 0 downloads I just did a re-install on my working iSY and it's not fully installing or working. It doesn't get to the installed state for me of prompting for OAuth even. I don't know what is going on. I'll look at it when I can. I just came back from the dentist with a double extraction. Fun! So I'm not going to be functional for a bit. Link to comment Share on other sites More sharing options...
bcdavis75 Posted December 12, 2020 Share Posted December 12, 2020 I havn't been posing every instance but just wanted to mention that the behavior generally hasn't changed. The node had to be restarted for me every few days and doesn't seem to be impacted by the lenthend short poll. I have a question on a separate topic though too which relates to both the polisy and PGC nodes; I have have nodes that should be removed related to zones I got rid of or appeared for reasons I'm entirely sure of. It's not clear to me how to remove an individual node. Link to comment Share on other sites More sharing options...
simplextech Posted December 12, 2020 Author Share Posted December 12, 2020 29 minutes ago, bcdavis75 said: I havn't been posing every instance but just wanted to mention that the behavior generally hasn't changed. The node had to be restarted for me every few days and doesn't seem to be impacted by the lenthend short poll. Sorry to hear this. With the nature of the cloud it seems everyone has different experiences and it's very difficult to isolate all possibilities. 31 minutes ago, bcdavis75 said: I have have nodes that should be removed related to zones I got rid of or appeared for reasons I'm entirely sure of. It's not clear to me how to remove an individual node. Nodes are created based on what's in your Sonos online account. You can remove the nodes from the Polyglot UI. Go to the NodeServer and click the "Nodes" button. Next to the nodes on the right is an "X" labeled Delete. That will delete the node from the ISY. However if the device still exists in your Sonos account it will be recreated on restart. Link to comment Share on other sites More sharing options...
