bcdavis75 Posted October 5, 2020 Share Posted October 5, 2020 46 minutes ago, glarsen said: Short poll 60, long poll 7200 Same Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 5, 2020 Share Posted October 5, 2020 6 hours ago, simplextech said: I need more information to determine if this is isolated to only this NS or not. If it is then I'll need to go in and do further debugging and try and find the root cause. Hi @simplextech, I only have one other PGC nodeserver, and that's Ring, which stays up through almost anything. This problem is limited to Sonoscontroller. Short poll 60, long poll 7200 here. Thanks for your work on this. Link to comment Share on other sites More sharing options...
simplextech Posted October 5, 2020 Author Share Posted October 5, 2020 14 minutes ago, Bumbershoot said: Hi @simplextech, I only have one other PGC nodeserver, and that's Ring, which stays up through almost anything. This problem is limited to Sonoscontroller. Short poll 60, long poll 7200 here. Thanks for your work on this. Ring as far as I'm aware (I've looked at it's code ) doesn't poll anything and instead receives data so that's a difference there. Ring is also written in JavaScript which is a different Polyglot Interface so that's different too. Well I've been meaning to put more time into SonosController and possibly a overhaul re-write is in store. I'll see what I can do to get this version stable. I re-installed it from PGC today on my test environment to let it just run and see if I can catch anything different. UDI is aware and I'm sure will help with pulling PGC info if needed. Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 5, 2020 Share Posted October 5, 2020 8 minutes ago, simplextech said: Ring as far as I'm aware (I've looked at it's code ) doesn't poll anything and instead receives data so that's a difference there. Ring is also written in JavaScript which is a different Polyglot Interface so that's different too. Well I've been meaning to put more time into SonosController and possibly a overhaul re-write is in store. I'll see what I can do to get this version stable. I re-installed it from PGC today on my test environment to let it just run and see if I can catch anything different. UDI is aware and I'm sure will help with pulling PGC info if needed. I can install the Tesla nodeserver and monitor it going forward. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 Found a couple of low hanging fruit I can resolve. Issue will effect if a player/group is added to the environment after the NS is running if the player/group was not added to the ISY previously. I'll get this updated soon. Development progress will be slightly delayed as I'm having to use my primary computer as my Testing system too as my "server" took a dump on me. New parts are ordered but not amazon Prime . So my CC's are now hurting and once the wife see's bill I'll be hurting Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 v0.2.9 - Experimental has LOTS of logging - Fixed issue with unknown node causing errors and potential crash - Fixed some typo's - Expanded logging with FULL DEBUG. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 v0.2.11 - Experimental LOTS OF LOGGING... STILL - Added name resolution check before sending any api request Link to comment Share on other sites More sharing options...
glarsen Posted October 6, 2020 Share Posted October 6, 2020 Got this.. sonoscontroller-0021b900ee84-8 (1).txt Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 6, 2020 Share Posted October 6, 2020 FWIW, I got this error on the previous version. 2020-10-06 06:57:22,568 [MQTT ] [DEBUG] Recieved Message: config 2020-10-06 07:45:24,530 [Controller] [ERROR] Exception in thread Controller: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 371, in connect ssl_context=context, File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 384, in ssl_wrap_socket return context.wrap_socket(sock, server_hostname=server_hostname) File "/usr/local/lib/python3.7/ssl.py", line 412, in wrap_socket session=session File "/usr/local/lib/python3.7/ssl.py", line 853, in _create self.do_handshake() File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() ssl.SSLError: [SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1056) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.ws.sonos.com', port=443): Max retries exceeded with url: /control/api/v1/households/Sonos_Vf4EGWq1koTooBJaVyufkOVHV5.ri7sR2ZLDIhpvEt0VyyG/groups/RINCON_48A6B845ABE801400:1507372996/groupVolume (Caused by SSLError(SSLError(1, '[SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1056)'))) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/app/nodeserver/sonos/sonos_control.py", line 35, in sonos_get_api req = requests.get(url, headers=self.headers) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 76, in get return request('get', url, params=params, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 61, in request return session.request(method=method, url=url, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request resp = self.send(prep, **send_kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send r = adapter.send(request, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 514, in send raise SSLError(e, request=request) requests.exceptions.SSLError: HTTPSConnectionPool(host='api.ws.sonos.com', port=443): Max retries exceeded with url: /control/api/v1/households/Sonos_Vf4EGWq1koTooBJaVyufkOVHV5.ri7sR2ZLDIhpvEt0VyyG/groups/RINCON_48A6B845ABE801400:1507372996/groupVolume (Caused by SSLError(SSLError(1, '[SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1056)'))) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 917, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 865, in run self._target(*self._args, **self._kwargs) File "/usr/local/lib/python3.7/site-packages/pgc_interface/pgc_interface.py", line 795, in _parseInput self.shortPoll() File "./SonosController.py", line 211, in shortPoll group_volume = self.SonosControl.get_group_volume(household, group_id) File "/app/nodeserver/sonos/sonos_control.py", line 148, in get_group_volume r_json = self.sonos_get_api(group_volume_url) File "/app/nodeserver/sonos/sonos_control.py", line 43, in sonos_get_api urllib3.exceptions.NewConnectionError, urllib3.exceptions.ConnectionResetError) as Ex: AttributeError: module 'urllib3.exceptions' has no attribute 'ConnectionResetError' Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 6, 2020 Share Posted October 6, 2020 11 hours ago, glarsen said: Got this.. sonoscontroller-0021b900ee84-8 (1).txt 11.93 kB · 2 downloads Probably no surprise, but I get this same error upon restart. Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 6, 2020 Share Posted October 6, 2020 Tried the version. Looks like it failed. guessing it's the same issue others are having. sonoscontroller-0021b902512a-2 (2).txt Link to comment Share on other sites More sharing options...
Michel Kohanim Posted October 6, 2020 Share Posted October 6, 2020 15 hours ago, bcdavis75 said: I can install the Tesla nodeserver and monitor it going forward @bcdavis75, unfortunately it seems that Tesla has blocked almost all traffic from public websites. Please do let me know if it actually works (it should not). With kind regards, Michel Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 46 minutes ago, bcdavis75 said: Tried the version. Looks like it failed. guessing it's the same issue others are having. sonoscontroller-0021b902512a-2 (2).txt 5.96 kB · 0 downloads @Bumbershoot This is interesting as I've been running all night ling from my test docker system. The difference being that it DOES NOT use the AWS servers. Is there something wrong in PGC/AWS I wonder? Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 LOL oh wonderful... so I just installed into PGC and yup same error... apparently the LOGGING python module won't install properly..... I'll remove it. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 Update without logging has been pushed. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 Stop and Start to pull the latest version for PGC. I'm running it now after another stop/start and it's loading and running. Link to comment Share on other sites More sharing options...
glarsen Posted October 6, 2020 Share Posted October 6, 2020 Running now, thanks! Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 6, 2020 Share Posted October 6, 2020 14 minutes ago, simplextech said: Stop and Start to pull the latest version for PGC. I'm running it now after another stop/start and it's loading and running. Yes, back in business here as well. Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 6, 2020 Share Posted October 6, 2020 20 minutes ago, Bumbershoot said: Yes, back in business here as well. Uh oh. Spoke too soon. sonoscontroller-0021b9022afa-14(10).txt Link to comment Share on other sites More sharing options...
glarsen Posted October 6, 2020 Share Posted October 6, 2020 Same sonoscontroller-0021b900ee84-8.txt Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 2 hours ago, glarsen said: Same sonoscontroller-0021b900ee84-8.txt 133.73 kB · 0 downloads ssl.SSLError: [SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:1056) Ohhh goody and SSL error... that's lower level than the nodeserver as the python requests library uses what's available on the system. Interesting that I'm not receiving any of those errors though. I wish the logging module would load in AWS so I could see what is making that call...... The other items in your is showing that groups/players exist in the Sonos system but are not created within the ISY yet. You should run re-discover. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 New update pushed with catch for SSLError Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 6, 2020 Share Posted October 6, 2020 1 hour ago, simplextech said: New update pushed with catch for SSLError So far so good. I'll keep an eye on it. Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 8 minutes ago, Bumbershoot said: So far so good. I'll keep an eye on it. I've been watching and I have not had any errors. But I didn't have any of the SSL errors that were reported either... so I dunno..... Link to comment Share on other sites More sharing options...
simplextech Posted October 6, 2020 Author Share Posted October 6, 2020 Found MY error in the logging issue. Updates pushed but I didn't increase version as it doesn't update anyways Restart and it will have very extended logging. Link to comment Share on other sites More sharing options...
